idle surge
Old Oct 17, 2009 | 11:52 AM
turnski's Avatar
CA idle surge
I have an Idle surge, the idle bounces between a rough 800 rpm up to 1500 smooth , at the rough idle I have flames comming out the tail pipes and it smells as though it running fat (realy rich). Ive gone through everything I can think of. TPS adjustment, Vacuum leaks, new plugs, ground issues, no codes, so what should I be looking for ? cause this has me stumpped.
Old Oct 17, 2009 | 01:09 PM
scrip7's Avatar
Rotary Gearhead
If you can post a video that usually helps us help you best. Have you checked timing with a timing light?
Old Oct 18, 2009 | 03:28 PM
turnski's Avatar
Yeah set the timeing with my light. this thing has got me ..and I seen a lot of stuff. guess it my lack of working on these things and just dealing with late modle plug and play stuff.
Old Oct 18, 2009 | 04:45 PM
AP3XW3TODD's Avatar
You probably already tried this, but I was messing with this last night and Ill try my best because to explain it. I do not know all the names for these things i was messin with. When you touch the gas pedal the lower throttle plate opens first. Find the arm that operates it. It's pretty obvious. I wish I had a diagram. But theres a screw (mine had a plastic cap over it) Turn it to the left with a flat head and see if that helps. If I don't make any sense tell me and I'll try again.
Old Oct 18, 2009 | 04:55 PM
AP3XW3TODD's Avatar
If this picture is legible, The 'arm' I'm talking about is in the bottom left and the screw is bottom center.
Old Oct 18, 2009 | 09:05 PM
AP3XW3TODD's Avatar
I mean bottom right not bottom left. sorry.
squirrels
Sep 1, 2024 09:52 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
NLPerformance
Oct 2, 2015 07:11 AM
