82 RX7 signal & gauge fuse failure short or ground
Old Oct 16, 2009 | 06:01 PM
back2midnight's Avatar
Posted - Oct 16 2009 : 3:17:06 PM Show Profile Email Poster Edit Topic Reply with Quote Delete Topic
Hi. This is my x wife's car (I know; "what a guy") and I have only looked at it once relating to her problem, I mean with the car. A fuse will blow causing the turn signals and the gauges to stop working, and a clicking noise is emanating from the fuse panel. The engine seems to be running well but a alarm sounds after a few minutes of operation. 1. Is this a grounding issue, and are the grounds easy to find and replace? 2. How do I diagnose this issue?
Thank you
Ron Armstrong
4sfeedit
Aug 16, 2015 01:42 PM
