Canadian Forum Canadian users, post event and club info here.
need calgary tuner advice, cold start problem e6x
Old Oct 12, 2009 | 06:08 PM
TalkSick's Avatar
wannabe racer
hopefully Syritus or 84 or someone can help me out, cars S4 TII guts, e6x ecu
cars runnin fine, starts great... warm
after we did that rip to cochrane i dug around, fixed the last of my vaccuum leaks and ever after had trouble starting it cold. say anything colder then 10 degrees and i have a horrible time startin it, once warm it fires right up.
im pretty sure its not flooding cuz if i kill the fuel i get no change
found a huge exhaust problem ill be fixin it tomorrow, blew the gasket between the turbo an manifold out, can that cause hard start?
anyhow the point of it is i need to know what sort of cold weather start formula the aftermarket ecu types are usin in the calgary area. lotsa fuel, a little fuel, timing etc? any help would be greatly appreciated
Old Oct 12, 2009 | 10:34 PM
Nismo Convert86's Avatar
400WHP or bust
Might want to take a look at your coolant, and AIT correction maps, or cranking map at lower temps.
Old Oct 12, 2009 | 11:17 PM
Syritis's Avatar
you got me on this one. Right now my E6X is running the BAC valve. it works well for holding idle but not for catching it. I never was able to figure out the starting maps.
Kyo
Apr 13, 2019 09:24 AM
sherff
Feb 24, 2019 12:09 PM
Microtech
30
Apr 23, 2016 06:37 PM
turbo-minivan
Aug 27, 2015 07:56 AM
Wolf_
Aug 11, 2015 04:23 PM
