new clutch not disengaging/engaging
Old Oct 11, 2009 | 05:50 PM
graedus's Avatar
over the summer i got a new clutch installed. noticed right away that the clutch felt really shallow, so i bled the clutch a bit and it started to feel more normal. however it has been grinding while shifting, mostly downshifting but upshifting too. then the clutch went shallow again and so i decided to try bleeding it again and it didn't work. now the clutch doesn't disengage at all and it's parked in front of my house. any ideas why this would happen with a new clutch so recently installed?
Old Oct 11, 2009 | 10:04 PM
Rx-7Doctor's Avatar
Sounds like your clutch hydraulics have failed.
Is the fluid in the Clutch master low?
Pull back the rubber boot on the clutch slave and see if their is fluid there. Also look under the dash where the clutch master bolts and see if there is fluid there.
Best thing to do is replace both Clutch Master and slave together.
Old Oct 15, 2009 | 10:57 PM
misterstyx69's Avatar
Retired Moderator, RIP
Did you change your Pilot bearing when you installed the new clutch?
.Try me on MSN (misterstyx69@hotmail.com).connect me.I'll bounce some suggestions off ya!
Old Oct 16, 2009 | 11:18 AM
graedus's Avatar
both bearings were changed when the clutch was replaced, i'll try you on msn.
Old Oct 16, 2009 | 12:13 PM
diabolical1's Avatar
it's more likely to be a hydraulic issue. based on your original post, it probably always was.
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
