Best pads for big brake/ rz?
Old Oct 11, 2009 | 04:33 PM
MILOS7's Avatar
Question Best pads for big brake/ rz?
JUST WANT TO KNOW WHICH PADS WILL BE THE BEST FOR MY BRAKE SET UP :
front brake:
2 piece rotor Project mu SCR-PRO : 314 X 32 MM slotted / 99' RZ CALIPER
rear brake :
1 piece dixcel : 314 X 20 SLOTTED /99' RZ CALIPER
SEARCHING FOR PADS STREETABLE ( low noise ) HAWK/AXXIS/ STOPTECH....?
Old Oct 12, 2009 | 08:59 AM
MILOS7's Avatar
bump
Old Oct 12, 2009 | 09:48 AM
Touge Monster's Avatar
RAWR!!!
I love Endless pads which our vendor Auto RND can get for you.
Old Oct 12, 2009 | 10:06 AM
ptrhahn's Avatar
Axxis Ultimates are nice, quiet, high performance street pads... Axxis deluxe might work if you want lower dust.
Old Oct 12, 2009 | 04:41 PM
MILOS7's Avatar
I VE ALREADY AXXIS ULTIMATE PADS ON OEM BRAKE SET UP ( lot of dust)
AXXIS DELUXE SEEMS NOT TO BE SO GOOD WIH FADING...
Old Oct 12, 2009 | 05:44 PM
MILOS7's Avatar
WHAT ABOUT 99 RZ PADS?
and where to buy it?
Old Oct 12, 2009 | 10:03 PM
Brent Dalton's Avatar
Sua Sponte
Are these pads just for street use?
Fade? What are you doing to get a pad to fade on the street? Are you talking brake pad fade or brake fluid fade?
Old Oct 12, 2009 | 11:34 PM
ptrhahn's Avatar
I was going to ask the same question... how the hell are you fading brakes on the street?!
I don't see the point in ordering some exotic imported Japanese pad for street use... plenty of sourceable-anywhere pads around. Heck, just get OE pads... the RZ brakes don't use a different pad shape.
Old Oct 13, 2009 | 03:55 AM
MILOS7's Avatar
actually , i'm searching for pads streetable but for use in track too ( no more than 2 laps / session/SPA Francorchamp/NÜrburgring)
Old Oct 13, 2009 | 09:01 AM
ptrhahn's Avatar
Unfortunately, there's no free lunch in brake pads.
That sounds more like a track pad you can "live with" on the street (there IS such a thing, depending on your tollerances), rather than a street pad which will hold up to track use (there's no such thing).
Even with a StopTech big brake kit and running on street tires, I began to fade Axxis Ultimates in less than a full lap at Summit Point (only 2.0 miles long). Tracks like Spa and Nurburgring, good luck with any real street pad. You'd be advised to simply switch pads, there's no good way around it.
However, you might try Porterfield R4E's, or N-Tech's "lapping day" pads. Anything like that, though, is still going to dust like ****, and wear qickly on the street, way more so than Axxis Ultimates.
Old Oct 14, 2009 | 12:53 PM
Sua Sponte
Ditto everything Peter said. As the bite increases, so does the dust. You might want to try the Hawk HP+ for a good street/autox/track day pad. You'll have to clean your wheels a little more, but won't be as bad as an all race/track pad like the DTC/blue's/01's, etc...
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
