My S8 Rx7 Spitters and stutters when i floor It! No Boost at all
Old Oct 11, 2009 | 08:35 AM
Rxxxxx7's Avatar
Unhappy My S8 Rx7 Spitters and stutters when i floor It! No Boost at all
Hey all. Have encountered a problem with my rx.
Just repluged the battery today to take her for a spin. First time i have disconnected the battery so it wouldnt die on me as I went on a 2 week holiday. Heated her up, started driving and all seemed fine under 2500revs. Went to floor it and all it did was spitter and splatter and stutter and was feeling like it was dying on me, so i eased off. Power seemed lumpy under 3ooorevs and stutters when full throttle.
Everything was fine 2 weeks ago. Only engine mods are airfilters and cat back exhaust. Stocko computer, turbos, intercooler, etc.
At first i originally thought dirty fuel/injectors, so i gave it a lil bit more only for it to only get worse. Had a quick check/lookover of engine bay, but nothing too obvious. Does not make boost at all.
Funny noise it makes is when i try to give a lil, then back off, it kinda makes a sound like when your turning off a vacum cleaner, a lil howling/vacum sound. I think possibly the stock Blow off valve opening????
I was think maybe fuel pump fault/computer fault???
Any suggestions?
Cheers
Old Oct 11, 2009 | 10:19 AM
Aaron Cake's Avatar
Engine, Not Motor
Sounds like it may be an intercooler pipe that has blown off, or other large intake leak.
Old Oct 12, 2009 | 09:06 PM
Rxxxxx7's Avatar
Also, it wont even go over 4-5000 revs. I was thinking intercooler pipe, but all seems good to me. One mate was saying to check sensors, as it is most likely electrical. Has this happened to anyone before?
Old Oct 12, 2009 | 09:22 PM
cptpain's Avatar
Torqueless Wonder
map sensor line popped off maybe?
Old Oct 17, 2009 | 08:17 PM
Rxxxxx7's Avatar
c'mon guys need your help on this...
Car will only make 2 psi of boost and its a struggle to get over 4-5000revs. Have checked intercooler pipes...
Where can i locate the airfolw meter or map sensor line?
I'm thinking that i may have blown the secondary turbo, hence the air leak, hence the low boost, hence the spitter and stutter.....
need some help guys... what does a blown turbo feel like???
Cheers all.
Old Oct 17, 2009 | 09:05 PM
dgeesaman's Avatar
Blown turbos don't do that.
Map sensor line is above your oil filter. Certainly worth looking there.
Injector issue is also a possibility.
Dave
Old Nov 12, 2009 | 11:10 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
u got book?
OrangeMax
Aug 22, 2015 12:05 PM
smikels
Aug 18, 2015 01:26 PM
86glxNA
Aug 15, 2015 01:45 PM
