Anyone used the SEM Interior Paint?
Old Sep 28, 2009 | 12:14 AM
F1blueRx7's Avatar
Couldn't stay away
Looking at re-doing my door plastics in either a dark silver/charcoal or a very dark red (would appear black when dark). I was wondering how SEM held up as apposed to a krylon acrylic. Mainly because SEM is so expensive, is it worth spending the extra money?
Old Sep 28, 2009 | 10:08 AM
SinSFDream's Avatar
yes
Old Oct 3, 2009 | 10:27 PM
scrip7's Avatar
Rotary Gearhead
I use SEM exclusively. I haven't tried any color other than Landau Black, which is the closest match with regards to sheen and color match on my 90 GXL and Vert restoration. I use Sem Soap first followed by Sem Vinyl Prep and then the color coat. On hard plastics I use Sem XXX Adhesion Promoter after cleaning and then the color coat. It's a durable finish, but as with any coating, don't scrimp on the prep. It's essential.
As for price, the color coat and prep is around $13 per can and is well worth it. Most other brands are either too flat, too glossy or have poor adhesion/flaking. I buy mine at a local paint & body supply company.
Old Oct 4, 2009 | 01:55 PM
cesarx7's Avatar
The Dirty Mexican
Originally Posted by scrip7
Thanks for the info. I too have been wondering about the quality of SEM paints.
Old Oct 9, 2009 | 10:20 PM
Mathieu18's Avatar
Dazed & Confused
Great stuff, I'm about to completely re-do the interior of an SA I'm rebuilding and change the colors. Thanks
Matt
Old Oct 10, 2009 | 08:43 AM
Mordachai's Avatar
_
We use it in the upholstery shop.
as Scrip7 said, it's all in the prep. spend your time prepping the parts and you'll be happy with the results.
Also we've been using bulldog for the adhesion promoter/flex agent, the end result seems to work better and hold up better than with using SEM's adhesion promotor.
And we ususally degrease any panels 2x before the SEM soap. After these plastics have been sprayed with Armour-all for years, it takes some time to get the greeeez off. We give it the double degrease, then after the SEM soap, don't touch the panel with your barehands. yes a single print of finger oils can make a panel look bad- try handling the panels by the edges or rear clips if you have to handle them at all...
SEM rocks.
Old Oct 11, 2009 | 08:13 AM
scrip7's Avatar
Rotary Gearhead
SEM rocks.
Good info. Do you have a preference on which degreaser?
Old Oct 13, 2009 | 11:53 AM
Mordachai's Avatar
_
greased lightning, simple green, the industrial purple **** at the shop,
any of them should be fine. you'll know it's working when the 'clear' degreaser runs off a dark brown...
jdayau
Nov 29, 2019 12:11 AM
acha3
Sep 6, 2015 08:14 AM
