Constant "Beeping" While Driving - WTF?
Old Sep 26, 2009 | 03:59 PM
NitrousJunkie's Avatar
86 N/A.
After driving for a bit, or maybe its only after I halfway get on it? I get this constant...beep...beep...beep...beep...beep, anyone have a clue what this is?
Thanks a much from a rotary newbie.
Chris
Old Sep 26, 2009 | 08:25 PM
w.sen's Avatar
In a Bucket
Does ur speedo work? Horn work?
Old Sep 27, 2009 | 10:10 AM
Aaron Cake's Avatar
Engine, Not Motor
Is it a beep or a buzz?
If it is a beep, and they come in counts of 5, then it is the power steering computer signalling a fault.
If it is a buzz, you have low coolant or low oil.
Old Sep 27, 2009 | 10:41 AM
w.sen's Avatar
In a Bucket
Ya if you are low on coolant it will buzz or if the coolant level sensor on the radiator is not grounded... the coolant acts like a ground.. The sensor looks like a plastic bolt with a wire check that wire for breakage...
Old Sep 27, 2009 | 11:50 AM
Ryan123's Avatar
The Slowskys
+1
Did you replace or mess with the power stearing at all?
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
