Haltech stock tps.....
Old Sep 26, 2009 | 12:04 AM
RXnos1200's Avatar
1200 gone......but......
stock tps.....
can the stock S5 TII tps be used on the E6K setup with decent results? If it can be used then where should the adjustment be set at? Thanks...........
Old Sep 26, 2009 | 09:03 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
it should work, you can calibrate it in the haltech software
Old Sep 26, 2009 | 09:19 PM
RXnos1200's Avatar
Thanks for the help. Is there a number I can specifically calibrate it too?
Old Sep 26, 2009 | 09:35 PM
C. Ludwig's Avatar
www.lms-efi.com
0-100% would be nice. Read the manual. The adjustment on the throttle body is for the short range sensor only which is not used by the Haltech.
Old Sep 26, 2009 | 09:57 PM
RXnos1200's Avatar
Thanks for the info. The car came with the E6K but not the manual. I'll go check the Haltech site and see if I can dl a manual.
msilvia
28
Apr 14, 2016 12:58 PM
