Non-seq and Sequential SWITCHABLE
Old Jun 7, 2002 | 11:33 AM
Wade's Avatar
With all the recent talk about non-sequential, I thought I would provide a link to Gene Felber's web site. Go to "The Car", scroll down to "How-To's", then go to "Boost Limit and Non-Seq switches".
http://www.purplemantis.com/Mantissa...ssa%20main.htm
The switch allows in-car toggling of sequential and non-sequential mode.
Wade
Old Jun 7, 2002 | 12:34 PM
Viper21's Avatar
Has anyone on this board done this as I'm interested in this modification too?
Mike
Old Jun 7, 2002 | 12:58 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
I'm trying it this weekend.
Old Jun 7, 2002 | 01:15 PM
7-sins's Avatar
thats not paint....
That looks pretty cool but with my beat sequential setup I wouldn't get any secondary boost. It's like a boost on and off switch in that case.
Old Jun 7, 2002 | 02:45 PM
puma's Avatar
canadian monster
i tried it, it works, cool to switch from the street for a seq setup to a non-seq on the track.
i also wanted to do it because i wanted to try the non-seq before a set of non seq.
decided i would stay seq.
puma
Old Jun 7, 2002 | 02:52 PM
rx7tturbo's Avatar
A question for anyone who have done this....How effective is this conversion since it just electronic wiring and nothing was done on the mechanical side?
The idea is great with switching between NS and S but I kinda doubt that it would be that simple...then again what do I know.
If anyone have done this and it's effectively switching between the 2 with no il-effect please post...I will definitely do this mod on mine if that's the case.
Thanks a lot.
Old Jun 7, 2002 | 02:59 PM
gfelber's Avatar
This is an awesome mod. Yes, I've done it myself (it's my page). It's great for the track- eliminates boost spikes!
If you have a modicum of soldering ability you should be able to do in in less than, say, an hour. If you want a nicer mounting like mine, then it will take a little longer to fabricate the braket.
Other benefits-
You can more easily pass emissions as the tester will be less likely to induce boost on the rollers.
Great for breaking in a new engine due to lower boost below 3500 RPMs
Great for warm-ups as you can much more easily avoid cold engine boosting.
Good for diagnosing upper RPM boost issues.
Good for tuning high-RPM/max boost (see below)
One other note- if you have a boost controller (elec or manual) this mods still works like a charm. In fact, I tune my Profec with the non SEQ switch. That way I don't have any surprises at the track.
Send me a note/PM if you have any Q's.
Regards,
Gene
Old Jun 7, 2002 | 03:01 PM
gfelber's Avatar
Thanks a lot.
No ill-effects other than somewhat laggy at low RPMs. It is laggier than the real non-seq mod. If you're concerned about low RPM boost, then you shoudn't be running the car in non-seq mode.
I've been using the switch for about 6 months now. No problems.
Gene
Old Jun 7, 2002 | 03:08 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Anyone other than Rikki (think he is running it...) running the PMS with the Non-Seq mod?
Old Jun 7, 2002 | 03:15 PM
rx7tturbo's Avatar
Gene, thanks. 1 more ?, I have the PMS and was wondering which mode should I go in on the PMS, the single or twin turbo mode? Would it control my boost like it should.
Hmmm...let me think about this abit.
Thanks.
Gene
Old Jun 7, 2002 | 03:20 PM
gfelber's Avatar
That' a good question
I'll defer to Wade.
Wade?
Thanks.
Old Jun 7, 2002 | 03:24 PM
rx7tturbo's Avatar
Gene,
You use IM, Yahoo or AOL? My AOL IM is "surpernsx".
Mark
Old Jun 9, 2002 | 09:30 PM
rx7tturbo's Avatar
DontBearikki,
Have you tried this switch method and if you have how is it compared to the one on your webpage?
Thanks.
Originally posted by Dont_Be_A_Rikki
I switch it to single but I heard it does not make a difference but did it anyway
Old Jun 9, 2002 | 09:47 PM
rx7tturbo's Avatar
Gene,
Per your instruction on the webpage, the 3 wires going "TO Solenoid", is it referring to the 4U wire on the back of the ECU or is it going to an actual Solenoid?
Thanks.
I'll defer to Wade.
Wade?
Old Jun 9, 2002 | 10:22 PM
Rx-Revin's Avatar
can u use the power fc or no.
Old Jun 10, 2002 | 08:16 AM
Wade's Avatar
I like it pretty cool but to me plugging 7 vacuum lines and wire'n the tca open IS MUCH QUCIKER AND EASIER... THANX WADE STILL VERY COOL
Huh? Are you saying you can switch between sequential and non-sequential, and back, as often as you like, and it is quicker to do that by wiring the TCA open than it is to flip a switch in your cockpit? It only takes about 1 second to flip that switch.
Wade
Old Jun 10, 2002 | 08:21 AM
Wade's Avatar
As far as the PMS setting, I don't know, sorry (I use sequentials). You'll just have to experiment!
Wade
Old Jun 10, 2002 | 08:35 AM
jspecracer7's Avatar
1JZ powered
Sure can!
Old Jun 10, 2002 | 10:39 AM
Wade's Avatar
Ryan,
Yeah, your way is probably easier if you like wrenching better than wiring.
Anyway, I just brought up this mod so people could try it and switch back and forth a bit until they decide. Then if they decide they like non-sequential they could gut the solenoids, lines, and some of the flappers.
Wade
Old Jun 10, 2002 | 12:39 PM
c00lduke's Avatar
i think 230ohm
Old Jun 10, 2002 | 12:47 PM
c00lduke's Avatar
i think 230ohm
