Megasquirt stage injection
Old Sep 16, 2009 | 06:28 PM
elturbonitroso's Avatar
stage injection
alright guys lets talk about stage injection. what should be the stage scaling factor if you have difference size injector,delay times.are there any calculation to follow in this process. im going to tune a car that have 850 primary and 1600 secondary what the scaling factor should be and delay time for this set up.also where do you found a better transaction on boost or in vac areas what technic do you found better.thanks
Old Sep 18, 2009 | 01:47 PM
Aaron Cake's Avatar
Engine, Not Motor
Copied and pasted from my Megasquirt tutorial:
The scaling factor you enter here will be dependant on the size difference between the primary and secondary injectors. "255" is the number to be used when both injectors are the same size as is OEM in all stock 2nd gens. If you have a larger secondary injector, you must calculate a new scaling factor. To do this, use the following equation:
Scale factor = Primary Injector Size/(Primary Injector Size + Secondary Size)* 512
So if we have 550CC primaries and 1680CC secondaries, it would look like this:
Scale Factor = 550/(550 + 1680)* 512
Scale Factor = (550/2230) * 512
Scale Factor = 0.246 * 512
Scale Factor = 126 (actually 125.9 but I rounded)
You must perform this calculation otherwise the car will be very hard to tune as the secondaries come online and the map will end up with a massive difference in values around the stage point.
I always set my staging to 3500 RPM and 90KpA, which is roughly similar to the stock 3800RPM and 2". Your staging delay is over how many engine cycles the stage takes place. A larger value will give a smoother stage. 60 is a nice point to start at.
Old Sep 20, 2009 | 07:56 PM
ok i think i got it. but the car its running real good in the vac areas if i changes the scale factor to a different one would that affect the tune that i already have done in the vac areas.thanks
Old Sep 21, 2009 | 09:36 AM
muythaibxr's Avatar
MegaSquirt Mod
Changing the scaling factor will change the tune anywhere the secondaries were coming on.
Ken
Old Sep 21, 2009 | 03:14 PM
ok good since im not have touch the boost part and im going to stages the secondaries at 6 psi so my tune and time tunning the vac area its not waste.
Old Sep 25, 2009 | 09:09 AM
Aaron Cake's Avatar
Engine, Not Motor
Uh, don't do that. Stage your secondaries where they should be in the first place, at around 3500 RPM and 90 KpA. If you stage at 6 PSI, you will find yourself out of fuel well before then and you'll end up having to retune half the map.
Old Sep 25, 2009 | 10:16 AM
eage8's Avatar
1308ccs of awesome
also if you get the settings wrong you could run really lean when you stage and at 6 psi that's not really ideal...
I would suggest either doing what aaron suggested, that's about how I have mine set up except instead of RPM I'm using injector duty cycle.
Old Sep 25, 2009 | 12:33 PM
muythaibxr's Avatar
MegaSquirt Mod
Actually, the way you're set up now (and the way I'm set up) allows for you to set staging between 0% staged and 100% staged or anywhere in between on a 6x6 table. It's not duty based at all.
It has also really smoothed out things for me, and makes it so I can freerev as high as I want with no sputtering, I can blip to downshift without staging coming on when I don't want it to, and I can't feel it stage at all... it's completely seamless. Looking at the AFR, it doesn't change at all in response to staging.
Ken
Old Sep 25, 2009 | 08:25 PM
i have done it that way with others ecu and no problem at all but im going to try that 90 or 100 kpa and lets see what happen remember the primaries are 850 and thanks
Old Sep 27, 2009 | 09:49 AM
Aaron Cake's Avatar
Engine, Not Motor
That's a bit of a scary way of doing things, but if it works for you then I guess it works. Personally I'd just set it up properly from the beginning as I don't see the advantage of not tuning it from the start.
Old Sep 27, 2009 | 12:31 PM
i took the car for a spin and when the car boost 4 psi the aem read a lean condition so im going to try to stage at 90kpa and let you know what happen.thanks
Old Sep 27, 2009 | 04:53 PM
eage8's Avatar
1308ccs of awesome
Ken
Now I look like a dummy
I had forgotten I had switched to the new beta staging code.
Old Oct 24, 2009 | 09:28 PM
i need help from you guys i still dont get this stage injection to work i will post a msq and a datalog when i get home.
Old Oct 24, 2009 | 10:04 PM
here are the msq and a datalog
Old Oct 24, 2009 | 10:19 PM
Old Oct 24, 2009 | 10:29 PM
ok i can get this attachment to work i need some help here too.
Old Oct 25, 2009 | 10:28 AM
Aaron Cake's Avatar
Engine, Not Motor
ZIP it, then attach.
Old Oct 25, 2009 | 11:36 AM
still can i send you the msq and the datalog.
Old Oct 28, 2009 | 09:03 AM
Aaron Cake's Avatar
Engine, Not Motor
What is the error or problem?
Old Oct 28, 2009 | 07:11 PM
for some reason i cant zip files on my old laptop.
Old Oct 31, 2009 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
Download something like iZarc, a free ZIP utility.
Old Nov 7, 2009 | 07:05 PM
i think i found the problem im going to try again soon.
Old Nov 13, 2009 | 08:18 PM
problem solve car was running so good until the rear plate crack now its time to get a rear plate and back to the tunning.
Old Nov 14, 2009 | 10:56 AM
Aaron Cake's Avatar
Engine, Not Motor
If the rear plate cracked, something is seriously wrong. Ridiculously lean mixtures, ignition noise, etc. Fix it or you will crack more plates.
Old Nov 14, 2009 | 09:26 PM
the only thing im thinking its previous leans condition due to previous problem with the injector wiring or the boost cut that i hit it a couple times but its set to cut spark and this should not be a problem i think .i dont think i have noise in the ignition because i dont see any noisy rpms in the datalogs rpms seen very clear and the a/f are in the 10s.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
lnlreaper
Sep 27, 2015 09:59 AM
