Rx7Store extreme fuel kit???
Ok i am looking to upgrade my fuel system. I am currently pushing 429whp@15psi(Sunoco Gt plus) and am lookin to reach over 500whp@2x psi..... My actual fuel setup is :
850cc x4 injectors (Placed Stock Secondaries in Primaries)
Supra denso pump (Rewired)
Stock fuel lines and pressure
New fuel filter.
I like the rx7store extreme fuel kit. Does this bring everything i need for 500whp?
Does it include the fuel lines? What is the banjo kit? Does it include it? Can i continue to use 850cc primaries or must i return to 550cc?
Anyone using this kit?
New fuel filter.
The extreme kit comes with everything needed to install and you can use your 850cc primarys up front. That will handle 500+HP.
It includes the Banjo bolt to hook up the stock primary rail.
Sorry, to answer your question, yes it will be fine for what you're looking to push. You may want to switch to a Bosch 04x pump to push a little more fuel to be safe.
Last edited by Trots*88TII-AE*; Sep 9, 2009 at 05:57 PM. Reason: didn't read question :/
