Microtech Another No Start Thread
Old Aug 22, 2009 | 12:53 AM
drugblock12a's Avatar
WON'T FORGET DAVE
Alright here we go. Some backround info
-Rebuilt S4 T2 engine
-Large streetport
-Stock turbo
-Stock 550s
-255 pump
Will not start. Orange light is blinking. I am getting spark and fuel (too much I think). Tps is as it should be. Fresh spark plugs. I am getting a RPM error every few tries. I'm pretty sure I'm on the timing. I have it set to the yellow mark and have the CAS stabbed properly.
If i'm lucky I can get it to start and it will rev to about 3k and die.
Should my map start the car without my foot on the throttle a bit? Could it be a timing issue? Everything appears to be on working order on the microtech.
This is my map.
Idle Map
Screen 1
30" ~ 1.33
25" ~ 1.48
20" ~ 1.43
15" ~ 1.86
10" ~ 2.48
05" ~ 3.48
00" ~ 4.0
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 1.52
25" ~ 1.52
20" ~ 1.52
15" ~ 1.91
10" ~ 2.5
05" ~ 3.50
00" ~ 4.4
2psi ~ 5.62
4psi ~ 6.10
6psi ~ 7.14
8psi ~ 7.86
10psi ~ 8.48
12psi ~ ???
14psi ~ 8.71
16psi ~ 9.00
18psi ~ 9.48
20psi ~ 10.00
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 15
Pump1Pulse ~ 03
Pump1Trig ~ 13
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-1 ~ 55
5 ~ 50
11 ~ 50
18 ~ 45
24 ~ 35
31 ~ 30
38 ~ 20
46 ~ 15
60 ~ 12
68 ~ 8
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 50
18 ~ 46
24 ~ 38
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ -02
6psi ~ -04
8psi ~ -06
10psi ~ -08
14psi ~ -12
16psi ~ -14
18 psi ~ -14
20 psi ~ -16
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 150
4000 ~ 180
4500 ~ 210
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
Old Aug 22, 2009 | 10:35 AM
Aaron Cake's Avatar
Engine, Not Motor
If you are receiving an RPM error, then the Microtech is having issues with noise on the CAS wires.
It's easy to prove too much (or too little fuel), though your map looks fine. Just increase the current load point of the water map and try to start the car.
If all else fails, a push start always works.
Fix the CAS errors first.
Old Aug 23, 2009 | 04:01 PM
WON'T FORGET DAVE
Cas errors are now gone. A push start is out of the question. I don't have the means.
I have noticed inconsistent fuel pressure so I am re plumbing my fuel system to run in series with the aeromotive FPR with gauge. Could this have been the cause of some of my problems? I was seeing anywhere from 30 to 40psi. After I finish the fuel system I want to see a solid 40psi.
I did try to increase the water map and got a few sputters but no start. I'm hoping it was the fuel pressure.
Thoughts?
This is what I am seeing:
LOG RPM LOAD T.P.S. Timing Output Water Air Battery AFR Aux 1 Aux 2 Status Errors
# 1 0000 -02 Hg 00% 00° 11.57sT 31°c 20°c 12.32v 19.0 . . IDLE . '
# 2 0000 -02 Hg 00% 00° 11.57sT 31°c 20°c 10.56v 19.0 . . IDLE . '
# 3 0000 -03 Hg 00% 00° 11.57sT 31°c 20°c 10.56v 14.7 . . IDLE . '
# 4 0000 -04 Hg 00% 00° 11.57sT 31°c 20°c 10.82v 11.0 . . Crank . '
# 5 0000 -04 Hg 00% 00° 11.57sT 31°c 20°c 10.95v 11.0 . . IDLE . '
# 6 0320 -05 Hg 00% 00° 11.57sT 31°c 20°c 11.00v 11.0 . . IDLE . '
# 7 0000 -05 Hg 00% 00° 11.57sT 31°c 20°c 11.12v 11.0 . . Crank . '
# 8 0320 -07 Hg 00% 00° 11.57sT 31°c 20°c 11.12v 11.0 . . IDLE . '
# 9 0320 -07 Hg 00% 00° 11.57sT 31°c 20°c 11.18v 11.0 . . IDLE . '
# 10 0320 -07 Hg 00% 00° 11.57sT 31°c 20°c 11.25v 11.0 . . Crank . '
# 11 0380 -08 Hg 00% 00° 11.57sT 31°c 20°c 11.25v 11.0 . . Crank . '
# 12 0440 -09 Hg 00% 00° 6.90sT 31°c 20°c 11.38v 11.0 . . IDLE . '
# 13 0380 -09 Hg 00% 00° 11.57sT 31°c 20°c 11.38v 11.0 . . Crank . '
# 14 0380 -09 Hg 00% 00° 11.57sT 31°c 20°c 11.38v 11.0 . . IDLE . '
# 15 0380 -09 Hg 00% 00° 11.57sT 31°c 20°c 11.25v 11.0 . . Crank . '
# 16 0380 -10 Hg 00% 00° 11.57sT 31°c 20°c 11.18v 11.0 . . IDLE . '
# 17 0440 -10 Hg 00% 00° 6.90sT 31°c 20°c 11.38v 11.0 . . Crank . '
# 18 0500 -12 Hg 00% 20° 6.43sT 31°c 20°c 11.44v 11.0 . . IDLE . '
# 19 0380 -12 Hg 00% 00° 11.57sT 31°c 20°c 11.44v 11.0 . . Crank . '
# 20 0380 -12 Hg 00% 00° 11.57sT 31°c 20°c 11.32v 11.0 . . IDLE . '
# 21 0380 -12 Hg 00% 00° 11.57sT 31°c 20°c 11.18v 11.0 . . Crank . '
# 22 0440 -12 Hg 00% 00° 6.76sT 31°c 20°c 11.44v 11.0 . . Crank . '
# 23 0380 -12 Hg 00% 00° 11.57sT 31°c 20°c 11.25v 11.0 . . IDLE . '
# 24 0380 -12 Hg 00% 00° 11.57sT 31°c 20°c 11.25v 11.0 . . Crank . '
# 25 0380 -12 Hg 00% 00° 11.57sT 31°c 20°c 11.25v 11.0 . . Crank . '
Old Aug 23, 2009 | 05:44 PM
rx72c's Avatar
Top Answer: 1
Your map looks good.
Your plugs look bad.
Is your engine rebuilt?
Old Aug 23, 2009 | 07:36 PM
WON'T FORGET DAVE
Engine is rebuilt with 30 miles. It is good.
Plugs are brand new out of the box. They are cold range tho. Only ones I could find.
Old Aug 24, 2009 | 07:39 AM
rx72c's Avatar
Top Answer: 1
Theirs your problem.
Chuck some oil in it.
And take it for a drive.
Old Aug 24, 2009 | 08:49 AM
Aaron Cake's Avatar
Engine, Not Motor
I'm not exactly sure what you are referring to regarding the fuel pressure, but yes, inconsistent fuel pressure is a major issue. Going from 30 to 40 PSI dramatically increases the amount of fuel from the injectors, and going the opposite direction does the reverse.
Old Aug 24, 2009 | 11:04 PM
WON'T FORGET DAVE
It was the fuel pressure. It was bouncing around far too much. Not to mention the either the microtech or the fuel pump relay that comes out of the mircotech was shutting off the fuel pump whenever it wanted.
So I ran a fused switch separately so I can control my fuel pump how I like.
The cold range plugs worked fine once I got the fuel pressure stabilized. The first crank got her running once I had 40 psi.
Thanks for all your help. This board makes me glad to own a 7 and run a mircotech.
Here's a picture of my new fuel setup. Cost a pretty penny but I made it myself and I'm glad this issue got me off my *** to do an upgrade.
http://i277.photobucket.com/albums/k...gie54/fuel.jpg
Old Aug 26, 2009 | 09:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Having a switch controlled fuel pump is unsafe. In the event of a collision, the pump will continue to run and potentially spray high pressure fuel all over the place. Major fire/explosion hazard.
The Microtech primes the pump and keeps it running as long as it is receiving ignition triggers. It sounds like you may have had a defective relay. I seriously recommend just getting a new relay and connecting up the Microtech's fuel pump control.
Old Aug 26, 2009 | 11:10 AM
WON'T FORGET DAVE
I will definetly do that today once I get to the auto parts store. I just needed it running so I could get there. My old man's POS malibu died and he's using my second car so I was left on foot with no rx-7.
streetlegal?
Mar 17, 2022 02:46 PM
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
85TIIDEVIL
Aug 25, 2015 12:09 AM
