6port
Well, you'll already have the 6PI and VDI solenoids on the rack, so you just need a way to trigger them. 2 RPM switches from summit racing will do it. They're about $50 a piece, and you can set them to 3800 RPM & 5200 RPM. On an S5 ACV, there is a nipple that will be your air source, and then there are metal hardlines going from there to the solenoids, then to the two aux. port actuators and the VDI actuator.
I have a couple of after market shift lights that are ajustable. If i used the wire that turns the bulb on (the shift light) to turn on the VDI and the 6PI sylenoid (i would use 2 one for each) would this work?
Trending Topics
jacobcartmill
Apr 30, 2003 01:53 AM
digger
16
Feb 14, 2002 08:23 AM
Silver88GXL
Feb 10, 2002 04:08 PM
BLUE TII
15
Jan 3, 2002 10:30 PM
