Megasquirt ok still not matching up.
Old Aug 19, 2009 | 10:08 AM
a_reyes1014's Avatar
hey guys i have the aem wideband uego kit and i cant seem to match the afrs from the gauge to tunerstudio or megatune. it makes tuning a little bit annoying. i have my wideband grounded to where the ms is grounded to. is there anything else i should do to make sure its seeing the same voltage?
Old Aug 19, 2009 | 10:17 PM
muythaibxr's Avatar
MegaSquirt Mod
Are you sure you calibrated the uego to the right 0-5v output, and the MS to work with that 0-5v output?
Ken
Old Aug 22, 2009 | 02:39 AM
yea its the linear 32-42xxx calibration right?
Old Aug 22, 2009 | 07:47 AM
muythaibxr's Avatar
MegaSquirt Mod
I don't know. I would assume the AEM has 2 0-5v outputs... 1 linear and 1 not. If the linear one doesn't work try the non-linear one.
Ken
Old Aug 22, 2009 | 10:30 AM
Aaron Cake's Avatar
Engine, Not Motor
I am no familiar with TunerStudio, but I always uses these gauges when I do a Megasquirt installation. In Megatune, it is the Linear 30-42xxx calibration.
Old Aug 22, 2009 | 10:45 AM
muythaibxr's Avatar
MegaSquirt Mod
Alright. In that case there must be a voltage offset still, or the calibration is not loading properly.
How far off is it?
Ken
Old Aug 25, 2009 | 03:31 AM
its off about .7 to 1.0 leaner than the gauge.
Old Aug 25, 2009 | 03:33 AM
actually the guage harness comes with a 0-5v wire and a wire you connect to a serial pin. is this the two outputs you are talking about?
Old Aug 25, 2009 | 09:31 AM
muythaibxr's Avatar
MegaSquirt Mod
I was talking about the 0-5v wire. Most other widebands I've seen come with a 0-5v wire and a 0-1v wire, and both can be programmed to output whatever you want.
It really just sounds to me like you've got a ground offset between the MS and the wideband.
So go over for me again how you have everything grounded?
Ken
Old Aug 27, 2009 | 11:23 PM
I'm using the relay board so I have that ground going to motor and the ground from the wideband going to the same point on the motor. I also have a ground running all the way back to battery ground post coming from the same point on the block.
Old Aug 28, 2009 | 10:24 AM
muythaibxr's Avatar
MegaSquirt Mod
Maybe try grounding the wideband on the relay board?
Again, unless the calibration for that controller is just plain wrong, the only thing that can cause this is voltage offsets between the wideband and the MS.
IF you know the calibration and it's a linear calibration, you can try hand-entering it in MegaTune or TunerStudio.
Ken
Ken
squirrels
Sep 1, 2024 09:52 AM
NLPerformance
Oct 2, 2015 07:11 AM
