No response from gauges
Old Aug 17, 2009 | 07:39 PM
Braker41's Avatar
IA No response from gauges
in my 87 rx7 13b na i have no response from anything, lights, ignition, gauges, nothing, all fuses are good and replaced, what can be the problem here?
Old Aug 17, 2009 | 07:52 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Test fuses with a multimeter, not just by looking. Start with the main fuse under the hood.
Old Aug 17, 2009 | 11:26 PM
BomberMan's Avatar
Does the car start? how are the relays? If you REALLY have nothing, check the battery, AND the battery terminals and cables for corrosion and connectivity.
Old Aug 18, 2009 | 10:26 AM
Braker41's Avatar
IA
it was running, i went to go get gas and came back and it wouldnt start then, when i was turning it over to start after getting gas there was a loud pop, then my gauged went dead and got the no response, there was a blown 7.5 fuse i repalced it and my gauges worked then i went to turn it over and they died.
Old Aug 18, 2009 | 11:23 AM
N3v's Avatar
N3v
might sound dumb, but check the battery connections. I had this same thing happen to me.
Old Aug 18, 2009 | 03:28 PM
Braker41's Avatar
IA
bat and everything is fine. now these "Relays" are u talking about the wires running from the fuses?
Old Aug 18, 2009 | 06:23 PM
IanS's Avatar
Ricer
Where in IA are you located?
Old Aug 18, 2009 | 07:07 PM
Braker41's Avatar
IA
Old Aug 18, 2009 | 07:23 PM
BotieRacing954's Avatar
FL
BY any chance is your wiring harness cut check that and check all of your wires sounds like something is shorting out pull all your gauges out and look behind them make sure you have no bear wires
Old Aug 18, 2009 | 07:25 PM
FL
all so check your ecu and the connections their
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
The1Sun
Sep 7, 2015 10:21 PM
