Fixed My Wipers
Old Aug 14, 2009 | 01:52 PM
mrlhand's Avatar
Fixed My Wipers
I followed the replacement procedure at this site for replacing the relays and now the wipers work like new. I used braided solder remover with a 30 watt soldering iron to remove the old relays. It takes many repeated applications of the braided rope to get all the solder off. If the relay does not come out easily, just hit it with the braided rope again. I was an electronics technician in the Navy for 25 years so I have done this many times before. If you can find liquid flux, the process works much better. Good luck, it is not that difficult to fix those wipers.
Larry
Old Aug 14, 2009 | 09:07 PM
mar3's Avatar
Administrator
Good to hear the website got you through that! What generation RX-7 are we talking about, though? Mind you, this question is only necessary since we're still in New Member tech where everybody's all tossed in together!
Mario III
Old Aug 15, 2009 | 01:47 AM
Rextasee's Avatar
808gxl
fc brah
Old Aug 15, 2009 | 09:06 AM
Chris_T's Avatar
Type Arrrr
Originally Posted by Rextasee
fc brah
Go figure. It must be a common problem in the FC. I replaced mine 3 times before they worked. Wipers and passenger auto window were the electrical plague.
dona1326cosprings7
Oct 29, 2015 06:47 AM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
WANKfactor
Sep 29, 2015 01:14 PM
