I cannot find an old post on emissions
Old Aug 10, 2009 | 08:58 AM
Rx-7heaven's Avatar
MI I cannot find an old post on emissions
Can someone please help me? I need to know if i can remove the tube comming off of the caltalactic converter going to the back of the engine. My car is a 86 N/A.
Thanks,
Mark
Old Aug 10, 2009 | 06:58 PM
IanS's Avatar
Ricer
Can you remove it? Sure. Should you remove it? Probably not. That hose runs your auxiliary port actuators. You will notice a large drop in power in the upper RPM range if you unhook that hose.
Old Aug 10, 2009 | 07:20 PM
Rx-7heaven's Avatar
well so far from what i just did today it didnt change a thing, but it did increase throttle control more. How?IDk I just know it did from the feel of the driving. And I had no decrease in purformance with the auxiliary port actuators since mine are partially stuck and the screws are messed up. (Prevision owner messed it up trying to fix them) Car runs good with straight pipes all the ways back to mufflers. (Apexi N1 Tip, rest custom piping) Runs great sounds GREAT! But I have a question on some brake calipers; do the heaver duty 4 piston calipers fit on my car? I have just the single piston calipers. Just wondering?!?!
Thanks,
Mark
Old Aug 11, 2009 | 11:48 PM
funkjaw's Avatar
Yes they will fit without a problem just get the 5 lug hubs to go with them.
streetlegal?
Mar 17, 2022 02:46 PM
