Sponsored by: CARiD
How to clean a wide band lambda sensor
Old Aug 9, 2009 | 06:55 AM
Speedworks's Avatar
I just pulled my wideband lambda sensor from my downpipe and found it was pretty black.
The car is currently on a base tune as I'm converting to single so fuel is off.
With what can i clean the sensor? as I guess it's quite sensitive
Water? brake cleaner? petrol?
paper? cloth? old toothbrush? paint brush?
Old Aug 9, 2009 | 08:19 PM
iani1.1's Avatar
DILLIGAF
some brake cleaner should do the trick.
Old Aug 10, 2009 | 06:10 AM
1990_fC3C_t2's Avatar
Idiot
wouldnt it be better to get a new one or better yet get an afr meter instead?
Old Aug 10, 2009 | 06:29 AM
Speedworks's Avatar
I have an LC1 kit
Old Aug 10, 2009 | 07:00 AM
Idiot
Sorry i misread your post!!!
is that similar to this?
http://www.dynojetwb2.com/
Im planning on getting the above wideband monitor because my o2 sensor is bent,
Do you need to weld in a new bung for the new wideband sensor or does it just replace your existing o2 sensor?
Thanks
Old Aug 10, 2009 | 07:48 AM
Speedworks's Avatar
My car is an FD and the OEM lambda sensor position is to short to the turbo's;
So yeah, mine needed a new bung to be welded in near the downpipe to midpipe flange.
in case of the Innovative kits, a new bung is always in the kit
Old Aug 10, 2009 | 08:53 AM
mono4lamar's Avatar
In the burnout box...
Carb cleaner or brake parts cleaner. My first choice would be carb cleaner as it's used on fuel system components and less hazardous to the sensor...
Old Aug 10, 2009 | 10:17 AM
Speedworks's Avatar
thx
Old Aug 10, 2009 | 04:40 PM
Romanator's Avatar
ya man use brake cleaner. Me 2 I have an LC-1 and I use brake cleaner and a dry clean cloth to clean it up and slap it back in.
Old Aug 12, 2009 | 07:46 PM
2J-Z's Avatar
brake cleaner would be your best bet if your using it just for driving around. If your using it to tune get a new one.
Old Aug 14, 2009 | 12:26 AM
iani1.1's Avatar
DILLIGAF
carb and brake cleaner are the same thing just different names
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
