Sponsored by: CARiD
"side port" "side porting" what do they mean? Street port?
Old Aug 6, 2009 | 06:41 PM
StavFC's Avatar
As title, you see sometimes, not often, seemingly mostly in Japan, the Panspeed Time Attack record breaking FD for example, the engine being referred to as being side ported.
Does that mean a particular type? Ie Street, Bridge, PP, etc?
Reason I ask is my car came over with a ERC "side port" engine, and ive no clue what that means
ERC are these btw, but their site makes no sense to me...
www.erc-rotary.com
Any ideas?
Old Aug 6, 2009 | 06:45 PM
blimp's Avatar
street port
Old Aug 6, 2009 | 09:20 PM
PercentSevenC's Avatar
I need a new user title
It could also mean bridgeport or half-bridgeport. Basically "side port" just means "not peripheral port". Likely they mean streetport.
Old Aug 16, 2009 | 01:02 PM
nyboriboy's Avatar
the new guy
side port is basically any port that isnt peripheral(port in rotor housing)...if u wanna get a better understanding of ports and other things pick up -HPBooks-1549 :Street Rotary by Mark Warner.
Old Aug 21, 2009 | 05:40 AM
kenn_chan's Avatar
Savanna Rx-7
Originally Posted by blimp
street port
correct
correct but incorrect, while you are technically correct, only a street port is called side port over here in Japan. mazdas first attempts at production rotatries all centered around a very small peri port. but they dropped that in favor of "side ports" so yes while any non peri port is technically a "side port" when dealing with the japanese, to them a side port is a street port and that pretty much covers from mild street ports to massive ones that the seals almost fall out of. bridge ports are bridge ports, but the japanese refer to them as small, or big ie: bridge ports and the larger "J" or semi peri ports.
kenn
Old Aug 21, 2009 | 12:40 PM
StavFC's Avatar
Thankyou Kenn, nice explantion
Old Aug 21, 2009 | 02:51 PM
I suspected that might be the case. Thanks for the clarification.
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
sYnth.
Aug 19, 2015 06:27 PM
Wolf_
Aug 11, 2015 04:23 PM
