Help timing 13b
Old Aug 4, 2009 | 08:37 AM
charlesclifton3's Avatar
Question Help timing 13b
can someone please tell me the procedure for making sure my timing is correct on my 1989 stock 13b rx-7 in the easiest and most comprehensive way .. thank you ..
p.s. ... please dont reply and say to read the book ... thanks
Old Aug 4, 2009 | 09:47 AM
Aaron Cake's Avatar
Engine, Not Motor
How about reading the book? Seriously, the timing check procedures are in the FSM and the Haynes. What's wrong with just looking them up?
The long and short of it is that you need to warm up the car fully and make sure it is idling at factory spec. Jump the initial set coupler and then put a timing light on the leading coil. Verify that the pointer on the front cover lines up with the yellow (leading) mark.
turbo-minivan
69
Feb 4, 2016 12:29 AM
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
