Engine Squealling?
Old Aug 2, 2009 | 09:54 PM
k-thoj's Avatar
Engine Squealling?
OK so when it starts it squeals, then stops after warming up, but when i drive it sometimes squeal if i down shift. I ask a buddy of mine he said it could be the wheel bearing? But idk. Anyone had this problem?
Old Aug 3, 2009 | 10:10 AM
Aaron Cake's Avatar
Engine, Not Motor
Sounds like belts or a bad accessory bearing to me.
Old Aug 3, 2009 | 07:21 PM
Jakesrail's Avatar
Need a little more info is it coming from the front, back, under the hood?
Old Aug 4, 2009 | 11:19 AM
k-thoj's Avatar
the squeling is coming from the front. it is loud so you can hear it even though i have a turbo exhuast on it. lol
Old Aug 4, 2009 | 11:31 AM
oppa637's Avatar
what side of the motor....
Old Aug 4, 2009 | 02:30 PM
k-thoj's Avatar
i dont' know what side?/ because i can't check it when i'm in the driver side? lol heres the story it is stock turboII engine. I haven't done anything with it, but it is a swap engine. I'll breif with the story. It is a turboII the previous own swap the engine to a different turboII. Because the old one was beat up etc etc. The only thing thats different on the engine would be the alternator pully. its an aftermarket blue one and a rotar oil cap. thats about it.
Old Aug 4, 2009 | 03:34 PM
Jeff5808's Avatar
Zoom Zoom
Does it only squeal when you drive it?
Old Aug 4, 2009 | 03:39 PM
KKMpunkrock2011's Avatar
dorito powered
try turning your fan off when it starts and see if the squealing stops too
Old Aug 4, 2009 | 04:09 PM
Aaron Cake's Avatar
Engine, Not Motor
So have you checked the belts and accessories as I suggested?
Old Aug 5, 2009 | 03:17 PM
k-thoj's Avatar
it squels sometimes when i drive it. Like down shift gears and gas it and only when its cold and starts up.
Old Aug 5, 2009 | 03:19 PM
k-thoj's Avatar
the fan was always off, due to the previous owner the ac dont' work so i just don't turn it on.
k-thoj's Avatar
i am not a mechanic so i do no know how to do so.
Old Aug 6, 2009 | 09:03 PM
Jeff5808's Avatar
Zoom Zoom
Do you know how to measure for belt deflection? A chilton or haynes manual will be able to give you proper directions. But in the mean time you can try this.
http://books.google.com/books?id=F5g...age&q=&f=false
You can also try a product called belt dressing. You put it on the belt and it is supposed to stop the belt squeal. But it will eventually wear off. If the dressing works, than it is safe bet that your belts are loose.
Since you describe it only as squealing when you down shift or gas it, I am 99.99% sure your belts are loose.
What car do you have?
Old Aug 7, 2009 | 04:11 AM
chri$'s Avatar
sounds to me like worn or loose belts
Old Aug 7, 2009 | 08:58 AM
Aaron Cake's Avatar
Engine, Not Motor
Take it to a mechanic. They can check the bearings in all the accessories with a stethoscope.
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
