1989 rx7 convertible problems
Old Aug 2, 2009 | 03:12 PM
c6vette4life's Avatar
NC 1989 rx7 convertible problems
Problem 1.
Driver's side window is broken. Cables are screwed. Does anyone know what type of cables can be substitutide for the stock ones without having to buy new regulator?
Problem 2.
Looking to do an engine swap away from the rotary to something better on gas, does anybody know if a 1990 model miata engine would work?
Old Aug 3, 2009 | 10:24 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't know about the regulator off hand. They are quite a reliable part and don't often fail so there isn't much of a demand for them. Consequently, they are cheap on eBay and on this forum.
As for engine swaps, check out the "Other Engine Conversions" subforum. Obviously it would take a considerable amount of work and fabrication to make such a swap.
Old Aug 3, 2009 | 08:55 PM
wildman88's Avatar
wildman88
I had the same problem, i had to get a new requlator. the cable and mechanisim are rebuildable and i saw an ad for a place in NY that does it, but i found a new regulator and motor at my local parts store, from Worldpack, that was just a bit more, but was new in the box Mazda part.
Old Aug 3, 2009 | 09:07 PM
Rotaryhaven's Avatar
Total Rotary Domination!
I have heard of people using either motorcycle or bicycle cables. do a search, there are a few here that fixed their regulator.
I would rather put a V8 than a miata engine. so make sure you get a good engine capable of moving that heavy convertible.
Sharkbait24
Aug 12, 2015 10:36 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
