Hard start and TPS issue
Old Aug 1, 2009 | 01:29 AM
Heavyfoot's Avatar
Car is a 93 rx7 automatic
first question is what is the wiring that connects to the TPS sensor supposed to read at the tip while its UNPLUGGED from the TPS sensor? 3F ECU is reading 4.9 volts while 3G ECU isnt reading anything. When i plugg in the new TPS sensor the most i can get by adjusting the TPS or ISC from either 3F or 3G wire is .03 volts.
Second question is what do you think is causing my slow crank? ignition switch and starter are brand new. Battery reads 12.9 volts, its an odyssey PC680.
Thanks for all the help.
Old Aug 1, 2009 | 04:24 PM
Heavyfoot's Avatar
ok i took off the TPS while it was connected to the wire to see if i could get the proper reading and its actually fine, but now everytime i try to put it back and get a reading then its allways off
Old Aug 2, 2009 | 06:49 PM
Heavyfoot's Avatar
ok TPS problem is fixed and the hard start issue i read on fd3s.net is beacuse my vin just happens to be one of the cars that have weak starter wires so as it gets hotter the resistance does also.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
incubuseva
14
Sep 3, 2015 12:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
