evo r projector kit
Old Jul 28, 2009 | 10:21 PM
superdan50's Avatar
Vroom Vroom Party Starter
evo r projector kit
does any one have the evo r projector kit? how is the high/low beam lighting from the 60mm projectors?
Old Jul 30, 2009 | 01:09 AM
superdan50's Avatar
since no one answered i will move this thread else where
Old Sep 4, 2009 | 07:33 PM
superdan50's Avatar
any help?
Old Sep 8, 2009 | 11:10 AM
Laz93RX7's Avatar
All Hail the Magic Conch!
I had the projector kit. but ended up fabbing my own, the lighting is terrible.
BEFORE
AFTER
Old Sep 8, 2009 | 11:12 AM
Laz93RX7's Avatar
which ones are you asking about, the original projectors or the 60mm?
Old Sep 9, 2009 | 11:15 AM
superdan50's Avatar
i am wanting to make my own kit, and was considering the 60mm projectors for mine. but i want to make sure the lighting doesnt suck. do you have any long distance night shots showing the beam pattern?
Old Sep 9, 2009 | 12:22 PM
Laz93RX7's Avatar
I think i got some before and after shots i'll have to look in my PC when I get home.
Old Sep 10, 2009 | 02:48 PM
superdan50's Avatar
sweet, thanx
Old Sep 10, 2009 | 03:36 PM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
Lighting is horrible unless you go HID. You can get the H3 white HID's and ballast for $60 through the vendor in the vendors section that fits the bulbs pictured above. $60 will do two lights, so you'd need two kits to do all 4 projectors.
Old Sep 10, 2009 | 03:38 PM
Built Not Bought
Top Answer: 1
I'm looking to replace the ones I use for high beams, let me know if you find anything that fits. right now i've got some larger lexus lenses which i adapted to the housing that came with the evo kit. I didn't get the distance right so a beam doesn't form.
Old Sep 14, 2009 | 11:34 AM
Natey's Avatar
I' in the process of getting blatantly ripped off by EVO-R for 400+ bucks on an ill-fitting light kit for my RX-7.
Steer clear.
Old Sep 15, 2009 | 09:16 PM
superdan50's Avatar
what do u mean "the distance was wrong and the beam doesnt form?"
Old Sep 21, 2009 | 04:38 PM
superdan50's Avatar
Old Oct 14, 2009 | 04:34 AM
Erdin's Avatar
Water Injection Specialist
Talking
BEFORE
AFTER
Any more pictures?
Old Mar 19, 2010 | 02:37 PM
superdan50's Avatar
i am exploring several options in my journey to make a better sleek kit. one of which is using the evo r projectors. does any one have pictures of the rvo r projector's cut off? and over all lighting?
also one route i will explore (the more promising one) will be using the projectors/reflectors out of another car. that way even thought the lights themselves are not DOT, the lights will be out of a DOT headlight. this way it will have the correct patterns.
my objective in this project is to offer a sleek kit with great fitment, great lighting quality and a great price (as well as looking good).
Old Mar 19, 2010 | 08:32 PM
Built Not Bought
Top Answer: 1
oh sorry, by distance is wrong, i mean the lights were modified, so the distance between the bulb and the lense isn't what it used to be (I had them modified by CinCity Designs), the lighting was bad, and i sent it to them to fix and be their first rx7 kit, but it came back even worse, with projectors, the distance between the lense and the bulb is important, just like your eyes (the lense and the reflectors in the back of the eye are at a very precise distance in order for them to focus)
Old Mar 20, 2010 | 12:31 PM
superdan50's Avatar
First, let me thank you for your input it has been very helpful.
Second is my question. is the lens you are referring to, the clear plastic cover? or the actual projector lens?
like i said i intend on using the assembly out of a DOT approved headlight, so if you are referring to the projector lens i should be in the clear. if you are referring to the clear cover i now have another hurdle to figure out.
Old Mar 21, 2010 | 12:46 PM
Built Not Bought
Top Answer: 1
I'm referring to the projector lense, it won't focus the light. I get a ring of light instead of a beam and it leaves it all dark in the middle so i can't see at all except for where the ring is, which is not on the road haha.
Old Mar 22, 2010 | 12:51 PM
superdan50's Avatar
gotcha
Old Jun 3, 2010 | 11:56 AM
NCGNETO90's Avatar
Tru Rotary Playa'
Can someone post pictures of what the kit looks like installed and how the lights are on the road?
Old Aug 30, 2010 | 08:22 PM
superdan50's Avatar
i know this is old, but to answer your question, go outside and light a book of matches. you can now see further the u can with the evo r kit.
Old Aug 30, 2010 | 09:30 PM
NCGNETO90's Avatar
Tru Rotary Playa'
Haha!!!!
Old Aug 30, 2010 | 10:20 PM
superdan50's Avatar
while i was joking a bit, its not far from the truth.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
REX7&Z32TT
Sep 14, 2015 08:46 AM
