89' rx-7 stockk 13b .. Help.. Wont start
Old Jul 27, 2009 | 10:09 AM
charlesclifton3's Avatar
Unhappy 89' rx-7 stockk 13b .. Help.. Wont start
ok hey i had an 89 rx7 hatchback but something went wrong with the electrical so i bought an 89 rx7 convertible with a blown engine and i put the hatchback's transmission and engine into the convertible body ... i replaced hoses and gaskets under the intake manifold .. hooked all the wires back up correctly .. i got it started a couple times but it would never idle and now it just wont start at all ... i know its getting fuel and spark and the timing is correct .. any thoughts as to why its not starting .. it will turn over but wont crank up ... PLEASE HELP
Old Jul 28, 2009 | 10:12 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Could be flooded, check your compression after you do a de-flooding procedure, search the forum for how to de-flood.
The1Sun
Mar 18, 2018 11:08 PM
Machupicchu
Aug 17, 2015 08:27 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
