Megasquirt THE TIME HAS COMe... WHO WANTS TO HELP WITH MEGASQUIRT INSTALL :D
Old Jul 9, 2009 | 08:08 PM
immanuel__7's Avatar
well the parts are here. I have been witting for this day since dj55b got his megasquirt installed!
now the time is mine. muhahah..
il see if dj55b cant build it for me before he goes on his 2 week long road trip.
but in the mean time what TPS and or therottle body do you guys use with the 13BTII S5 system? as i think i cant use the one i have now is that correct?
man i think im just as excited as i was when i was digging my rx7 out of the 6' shown banks in march 2003 to try and start her up for the first time.
Old Jul 9, 2009 | 10:43 PM
nu-rx7junkie's Avatar
A s5 tps is full range and if you are using a stock 13bt intake manifold the throttle body bolts right up. So that should be easy. The s4 throttle body is short range. Since you are turbocharged a map sensor should be all you really need anyway. Im using a s4 tps because If im not mistaken the tps sensor isnt going to help to much. But Ken or Arroncake will chime in (i bet) and give you a detailed explination.
Old Jul 10, 2009 | 12:36 PM
cool thanks i just hope the tps is ok as its making my car run all funny when its hooked up.
ok so if the s5 is full range then ya that should work ok, how should i adjust it?.. u know what il repost this ?? thanks for the help
Old Jul 10, 2009 | 03:39 PM
toplessFC3Sman's Avatar
The TPS allows you to do acceleration enrichments based on its motions, use the closed-loop idle functions, overrun fuel shutoff, launch control, boost control etc.
Old Jul 11, 2009 | 10:19 AM
Aaron Cake's Avatar
Engine, Not Motor
You can use any TPS and any throttle body. But logic says that you should use the one that came with your engine.
The S5 TPS is fine to use. It has both a narrow range and full range. The full range is ideal, but the narrow range will also work.
Ignore any weirdness with the TPS and stock ECU. It no longer applies.
Old Jul 13, 2009 | 12:17 PM
sweet, thanks guys.
Old Jul 18, 2009 | 12:29 AM
digging my car out in march :D
figured id post what my car looked like when i started with rx7
Attached Thumbnails THE TIME HAS COMe... WHO WANTS TO HELP WITH MEGASQUIRT INSTALL :D-third-car-rx7-original-paint-2004.jpg
Old Jul 31, 2009 | 01:57 AM
dj55b's Avatar
tsk tsk ... trying to cheat on me :P
Old Aug 4, 2009 | 01:59 AM
dj55b's Avatar
Well Martin, I actually figured out the Boost control thing now. So it should be good to go! Well minus the firmware update.
Old Aug 4, 2009 | 09:15 AM
Aaron Cake's Avatar
Engine, Not Motor
And don't forget the PWM idle valve mod! Guess I don't need to reply to your email about the boost controller.
Old Aug 4, 2009 | 08:45 PM
dj55b's Avatar
not sure what that is, but I'll try to look it up.
Old Aug 5, 2009 | 12:42 PM
thanks for the help guys i cant wait to start ripping out old parts
Old Aug 5, 2009 | 10:36 PM
if i use the GM Coolant temp sensor, will i need to tap and or have some one make a new hole for the GM sensor or will it just fit in the place of the OEM S5 one?
Old Aug 6, 2009 | 12:47 AM
dj55b's Avatar
drill and tap. I believe its 3/8" NPT
Old Aug 6, 2009 | 09:44 AM
err i hate doing stuff like that. i think im getting lazy
Old Aug 6, 2009 | 11:45 AM
muythaibxr's Avatar
MegaSquirt Mod
You know you can just use the stock S5 one as well? I just requires a calibration when you reflash the firmware.
Ken
Old Aug 7, 2009 | 08:43 AM
Aaron Cake's Avatar
Engine, Not Motor
On the front of the water pump housing there is a circular casting between the 3 bolts that used to hold the air pump bracket. It's the perfect spot and you don't have to remove the housing...
Old Aug 7, 2009 | 10:50 AM
:O i like great tips like this thanks AARON, look like next week will be a fun week
Old Sep 1, 2009 | 08:40 PM
well time for an up date, we did not finish the rx7 in time for 7 stock north, so i drive my wife to work and took her toyota to 7 stock.
now that time is on my hands i finished the interior intake is back on all wireing is done and done nice and clean thanks to dj55b.
ended up sending the intake to get taped with 3/8 pipe thread for the GM sensor, but since i sent dj55b to get the job done we got it done for free..... as dj55b bartered his way from 30 down to here's the tap do it your self come back when your done
so that got done wright, once that was all sayed and done we figured we might as well test out the MS, well as it turned out the second vr2 system is not working so we ended up re ordering all the components and having to deal with waiting a week to order an LM1815 as the guy did not want to order just for us... so today i dropped buy his store and offered him 20 more $$ for his 8$ parts (i really really miss my RX7) so he looked at his 6 other order's and toled me i could pay the 8$ shipping he would over night it them so now heres to hoping all works well and that dj55b can fix up me ms for this Friday for the Boston pizza meet. other then that the car looks/ well starting to look like a race car
I MUST ADD!!!
many many thanks to dj55b who put so many hours in cleaning up dual wiring harness to a few wires. and to making me do the job wright the first time
and a big thanks to Aaron cakes expertise with ms testing, info retesting and flasher/wiper box thing he provided and saved up many hours of rewiring my rx7
after an incident with a smoking dash board
Old Sep 2, 2009 | 02:40 AM
dj55b's Avatar
Lol ... you make me sound like I'm super **** about how I want my wiring done. its only PARTIALLY true lol.
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
