Sponsored by: CARiD
need to change diff fluid
Old Jul 8, 2009 | 11:20 AM
puertorican-RX7's Avatar
Exclamation need to change diff fluid
all i need is some quick instructions and tips. need to change my differential fluid
Old Jul 8, 2009 | 01:15 PM
jgrewe's Avatar
GET OFF MY LAWN
Drain it out the bottom, replace bottom plug, refill until it drips out the hole in the back.
Old Jul 9, 2009 | 10:54 AM
BARF1's Avatar
Who are you?
make sure top plug comes out before draining, you'll be sorry if it doesn't.
Old Jul 13, 2009 | 11:39 AM
what hole in the back
Old Jul 13, 2009 | 02:06 PM
WaachBack's Avatar
Finally Knows
The biggest bolt on the bottom. If you have a lift, it will make things WAY easier.
Old Jul 13, 2009 | 08:33 PM
jgrewe's Avatar
GET OFF MY LAWN
There is a plug/bolt head that is about half way up the back, just off center of the dome shape for the ring gear, it may even have a tag that says you have an LSD.
Old Jul 14, 2009 | 11:36 AM
impactwrench's Avatar
A very good piece of advice.
The1Sun
Sep 7, 2015 10:21 PM
