boost gauge reads 0 at idle
Old Jul 6, 2009 | 01:00 AM
The Red Cyclone's Avatar
alright guys my boost gauge only goes down to zero. It goes up under boost, but not down at idle. Its an aftermarket boost gauge installed on a s5 turbo swapped car. I can't imagine i have a vacuum leak big enough for vacuum to be 0 right? The car runs and idles ( a little roughly).
Old Jul 6, 2009 | 09:11 AM
Aaron Cake's Avatar
Engine, Not Motor
Where is the boost/vacuum source for the gauge plumbed into on the engine? Several of the nipples and lines are fresh air ports which lead to a pickup in front of the throttle plates. Plumb the line from the boost gauge into the line going to the pressure sensor on the passenger shock tower.
Old Jul 8, 2009 | 08:51 PM
Yeah, i think i accidently got into one of the fresh air ports. After much searching i eventually found out about this. So the pressure sensor also needs to be hooked up to the real vacuum line and not a fresh air port too right?
Old Jul 8, 2009 | 09:06 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Yes.
streetlegal?
Mar 17, 2022 02:46 PM
Snoopy FD
Dec 8, 2015 01:45 PM
TerryD
Aug 23, 2015 07:40 AM
