FD - Double checking fit before I order
Front - 18x9 +36 (Tire size: Undecided)
Rear - 18x10 +45 (Tire size: 275/45-18)
How well will these fit/look? All I'll have to do is roll the front fender slightly correct?
Thanks,
Nick
Thanks,
Nick
wheels:
front will rub, ideally you'd want a 9 inch width +45. Need fender roll at a minimum.
rear are fine.
tires: recommend 245/35 front to minimize rubbing.
rear: you'll want 275/35 or 285/30, the size you have listed is way too tall and will look monster truck-ish.
rear are fine.
wheels:
rear are fine.
rear are fine.
Thanks
No. More then likely you will be ok. And if you do happen to rub at all in the front, just roll your fenders out a little more. But I have 90% faith that with the lip rolled flat you will be just fine.
wheels:
rear are fine.
rear are fine.
If you are primarily drag racing and want bigger sidewalls, it would make more sense to get 17" rims.
I agree. I'll eventually get a dedicated set of rims with slicks and skinnies, but right now funds are SUPER tight and I can get these 18's at a killer price
Trending Topics
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
