question about rotor housings
Old Jun 22, 2009 | 11:30 PM
driftingmyFC's Avatar
Rotary Turbo
So I opened my engine up and my rear rotor housing is a f**ed up, here are the pics. so Im pretty sure is not reusable, this is from a series 5 turboII. so my question is can I use a n/a rotor housing for my engine even if its from an series 5??
Old Jun 22, 2009 | 11:51 PM
Rotary Turbo
here is the only broken apex seal that probably caused the damaged.
Old Jun 23, 2009 | 12:02 AM
Battle Cat's Avatar
Space cadet
the housing is done,
naw , the exhaust sleeves are differnt from n/a and turbo
Old Jun 23, 2009 | 12:17 AM
dsmhero's Avatar
Housing is toast. You can use an NA housing, I did. Few things to make sure of tho, there is a coolant hole for your turbo and if your ruined housing has this then you will need to drill out the NA plug and as stated above, there is an exhaust sleeve that you can grind out if you are willing to.
EDIT - What the hell is a piston doing in one of your pictures?!?!??!!!!
Old Jun 23, 2009 | 10:03 AM
Rotary Turbo
was just lieing around, its the one I hang from my tow hook
Old Jun 23, 2009 | 11:11 AM
dsmhero's Avatar
Haha nice!
Old Jun 28, 2009 | 10:09 AM
Rotary Turbo
what about a series 4 , Can I use a series 4 turboII rear rotor housing?
Old Jun 28, 2009 | 11:52 AM
rex7tuner's Avatar
TX yes
yea u can use any housings except the 12A and rx8!
thats wut i'm doing. just cut out or take out those NA sleeves!
Old Jun 28, 2009 | 12:03 PM
BLUE TII's Avatar
Rotary Motoring
NO
You cannot mix S4 and S5 rotor housings on the same engine. Mazda moved the spark plug location between the two.
If you want to use an NA rotor housing of the same series you can replace the exhaust port sleeve with the turbo housings. Use a small sheet metal screw to thread into the roll pins at the side of the housing and pull the pins out with pliers.
Old Jun 28, 2009 | 10:43 PM
Rotary Turbo
Originally Posted by BLUE TII
NO
Ok so you area saying if I get a s5 n/a housing I just have to SWAP the exhaust port sleeve with the one from my f'''ked up housing.? (no porting, just direct swap, maybe drilling for turbo coolant?)
Old Jun 29, 2009 | 12:03 AM
dsmhero's Avatar
you can swap the sleeve or do what I did. Took a carbide bit and ground out the diffuser fins in the N/A exhaust sleeve.
Old Jun 29, 2009 | 12:32 AM
Rotary Turbo
can someone post a pic of what needs to be done to a n/a housing to make it work, im having trouble picturing this process in my head.
Old Jun 29, 2009 | 11:04 AM
dsmhero's Avatar
I am at work right now but I can get you pictures tonight. Its not hard at all.
Old Jun 29, 2009 | 06:36 PM
Brice_Brice's Avatar
Longtime Lurker
Veteran: Air Force
if youre gonna rebuild an enigne then why not get the part that will fit without modifications? Sounds like one more thing to blow an engine
Old Jun 29, 2009 | 08:09 PM
2slow4stock's Avatar
The waiting game......
Also you'll most likely need a rotor if your housing is that bad.
Post pictures of it up.
Old Jun 29, 2009 | 09:26 PM
Rotary Turbo
These are the 3 faces from the rotor, I bet I can still use it, its the rotor that came from this housing 100% sure, I still have't disasembled the rest of the engine.
Old Jun 29, 2009 | 10:48 PM
wow, lucky. Congrats. So just find a housing and seals and your good to go.
Old Jun 29, 2009 | 11:25 PM
Rotary Turbo
hey bud will you happen to have just one extra apex seal?
cdn
14
Sep 10, 2015 06:23 AM
VTECthis
Aug 24, 2015 09:01 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
