Coolant leak HELP
Old Jun 21, 2009 | 11:04 PM
barnett87rx7's Avatar
lite rotary = easy push
Coolant leak HELP
Hi
so the buzzer started going off today so i was looking at all the houses and found nothing , so i decided to take the intercooler and and intake manifold off and look around. I found a coolant on the top of the block under neath the smaller fuel rail but did not find any hoses that were in bad shape. any help. i didnt tbink it could be the block since the pool was on the top.
Old Jun 22, 2009 | 01:09 AM
jjcobm's Avatar
Are you experienced?
Rent a cooling system pressure tester and pressurize your cooling system (usually through the radiator). You will find the leak in not time. Usually available at your parts store.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
