how eliminate the ACV?
Old Jun 21, 2009 | 03:29 PM
cmsgama's Avatar
Hi
I have a rx7 13bts5 and I buy a ACV cover plate to eliminate de ACV, but first, I want know if is easy eliminate the valve? what did i have to do? Did i will have error codes on the ECU?
Help Please.
regards
Old Jun 21, 2009 | 03:49 PM
Grip's Avatar
take the acv off, and bolt on the blockoff plate. dont forget to clean the gasket surface, use a new gasket, and a little RTV silicone..."T" your pressure sensor into the vac line for the BOV.
take the air pump off too, dont forget the canister under the headlight.
this has been discussed a million times, there are plenty of threads if you search around for a little while.
Old Jun 21, 2009 | 05:50 PM
cmsgama's Avatar
Thank's very much
What's pressure sensor? that near passenger strut tower?
and don't exist any problem the wiring loom stay disconected from the 2 sensors on ACV?
regards
Old Jun 21, 2009 | 06:48 PM
Grip's Avatar
leave the plugs for the ACV disconnected.
the pressure sensor/boost sensor is on the passanger strut tower, behind the air box. it has a vac line going to the bottom of it, and it has a resistor pill inside the line...dont lose that pill if you replace the vac line.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Bauer778
Nov 4, 2015 04:42 PM
