Sponsored by: CARiD
A/C Questions
Old Jun 18, 2009 | 08:22 PM
dcolon02's Avatar
A/C Questions
I have a 86 RX7 and the compressor is connected and the only thing it needs is the freon. When I go to push the button to the side to turn on the a/C nothing happens. Could someone help out and tell me what might be wrong. I dont understand it.
Old Jun 19, 2009 | 10:27 AM
dcolon02's Avatar
Help!!!
Old Jun 19, 2009 | 10:33 AM
evot23's Avatar
Classy
ac pressure switch not letting ac on since you have no freon.
Old Jun 19, 2009 | 11:42 AM
dcolon02's Avatar
So how do I do it? Put Freon and then turn it on...???
Old Jun 19, 2009 | 11:49 AM
dcolon02's Avatar
so this doesnt work the same as a regular car... I have to first fill it and then turn it on? Because on my civic I could turn it on and then fill it...
Old Jun 19, 2009 | 01:21 PM
evot23's Avatar
Classy
There have been numerous threads on this, just do a search and you'll find your answers.
Old Jun 19, 2009 | 05:09 PM
dcolon02's Avatar
So I searched and found nothing... Can someone please help me out... I started the car and put freon in it and the bar went to the yellow. I turned the switch on and nothing...Not even a sound.. I removed the unit and checked to see if it was plugged in and nothing. I checked the fuses and nothing is blown...
Old Jun 19, 2009 | 05:29 PM
evot23's Avatar
Classy
Check voltage at the wires to the switch to see if you have power running through it. Check relays for same. If you have voltage, good relays, no blown fuses is it possible your compressor is shot? If voltage goes through relays you should be able to hear them click.
evot23's Avatar
Classy
Did you post this in the 2nd gen section...may get more traffic there.
Old Jun 19, 2009 | 08:38 PM
cbrinega's Avatar
still love the FC
Here is a good thread on FC A/C systems:
https://www.rx7club.com/2nd-gen-archive-72/official-its-summer-there-going-million-ac-questions-thread-308839/
You can bypass the pressure switch to do a quick test. Just unplug the two leads and put a jumper wire across the plugs. (The pressure switch is near the coolant overflow tank.)
P.S. If you had the system apart, I hope you got all the moisture and air out with a vacuum pump before trying to refill it.
_Tones_
May 25, 2021 05:37 AM
