What turbo for my 12a?
Old Jun 11, 2009 | 05:02 PM
statique's Avatar
So I'm rebuilding a 12a turbo doing a semi pp ,and Bridgeport, and adding dowel pins cause I want to run n/a rotors...someone told me to run a 70a/r and a 96a/r hotside...
What turbo you think I should use...
It's gonna be a track/drift car, well let's just say a fun car lol
Old Jun 11, 2009 | 05:07 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
Gt40 70ar 1.15 hotside
Old Jun 12, 2009 | 12:14 AM
81gsl12a's Avatar
blown up motors
na the 96 will be better for drifting. if you want it to lag a lil less. kinda sounds like you are just making the motor as big as you can and throwing alot of stuff at it with out finding out what you need for a power goal but ah what do i know
Old Jun 12, 2009 | 12:55 AM
tasty danish's Avatar
Doesn't suck
power goals?
Old Jun 12, 2009 | 01:25 PM
Jeezus's Avatar
A 96 with a full bridgeport, yes, but with a PP on top of that, it would seriously choke the flow higher up.
Old Jun 12, 2009 | 01:48 PM
Kerebrus's Avatar
Do you need a turbo or already have one?
Old Jun 12, 2009 | 01:51 PM
Jeezus's Avatar
Also, with a full bridge and PP AND turbo, are you trying to drift with 1000 hp?
Just get a nice TII engine. Just a stock engine and turbo (with a higher stage TII turbo) will get you 400whp.
Old Jun 19, 2009 | 10:25 PM
statique's Avatar
ok i plan to do a bridge port with a semi peripheral port not a full peripheral
i want anywhere from 300 to under 400hp
basically i want a build that pushes an easy 400 hp but i want to tune it down to 300 or anything uder 400 so it runs strong and is spooling quickly from low to high rpm's
did i make that clear?
its not like i can go do numerous amout of runs trying out different types of turbos ( a shop that allows this for the best set up would be amaising lol) but im not trying to buy one turbo then find out theres a nother turb that would run better, i know what i want but when it comes to turbo choices.
Old Jun 19, 2009 | 11:01 PM
Rotor_king's Avatar
Quick question...how can you do a semi peripheral port?
Old Jun 20, 2009 | 12:19 AM
Doesn't suck
why are you doing crazy porting for power levels EASILY attainable on stock ports?
you want one of these:
gt35r, t04s 60-1, or t04e 60trim. stock ports all will hit 350 easy. the 35r is more $$ but will err towards more power and faster spool.
The t04e will hit do the job too and be cheap. Streetport it if you're concerned about meeting your power goals.
Old Jun 20, 2009 | 07:22 AM
blackdeath647's Avatar
weak minds wear the crown
just do a street port or a full bridge no point in going into all the trouble of doing weird PP's for 300-400hp lol...my buddy's bridge is making close to 200hp N/A, now he's got a turbo on it, can't wait to hear what its got lol
Old Jun 20, 2009 | 07:58 AM
MOBEONER's Avatar
It's finally reliable
true your car is light enough . I would go street port with a S5 t2 turbo since you are using high compression rotors and make an adapter since you have to custom make the manifold for the 12a anyway to go turbo. boost the turbo 10psi and go drift and save your self $$$
Old Jun 20, 2009 | 02:43 PM
Kerebrus's Avatar
S5 TII large street port with a hybrid T3/T4 . But really he can do just do a nice blowthru turbo setup on his 12a and make great power.
Old Jun 20, 2009 | 05:25 PM
....nothing smaller
Old Jun 20, 2009 | 06:14 PM
mojave's Avatar
Epic turbo is epic, what's that off of, a freakin' ocean liner?
Old Jun 20, 2009 | 09:07 PM
FbDrift's Avatar
most likely, some of the turbos they use for there diesals is crazy!
Old Jun 21, 2009 | 11:13 AM
jshiz's Avatar
Actin Like I'm Drunk
"drift/track car"? That's an odd combination
Old Jun 21, 2009 | 07:00 PM
FbDrift's Avatar
not really, if he goes adjustable, its really not that different.
Old Jun 21, 2009 | 08:51 PM
jshiz's Avatar
Adjustable what? Struts?
Old Jun 21, 2009 | 09:31 PM
Doesn't suck
struts don't make up for the massive rear spring differences drifters usually run compared to racers.
Old Jun 22, 2009 | 12:19 AM
jshiz's Avatar
I know. I was thinking that the set up between a track car and a drift car was completely different if they want to be competitive in either one...
Old Jun 22, 2009 | 12:44 AM
Doesn't suck
right, and for the record I gathered that you understood that and others in this thread didn't.
/jacking
Old Jun 22, 2009 | 01:40 AM
'87 turbo II's Avatar
Sleeper but still slow
How long have you been working on car's? Your goals sound.... well, to be frank and somewhat polite.. "uneducated".
Old Jun 27, 2009 | 11:15 PM
statique's Avatar
well im more familiar with n/a 13b's thats all
reading is different from doing, especially if you want the right set up, i just want to hear some of the peoples ideas heres my engine...
Old Jun 29, 2009 | 02:06 PM
trochoid's Avatar
Old Fart Young at Heart
My suggestion is to spend lots of time reading in the 2nd gen section to see what kind of hp they're making and how they're making it. Granted, there are some differences making 400 hp with a 12A compared to a 13B but the principles are the same. If you want longevity from your engine, start with a TII block, preferably an S5, and go from there.
