Microtech wont rev!!
Old Jun 7, 2009 | 02:54 PM
666cody666's Avatar
wont rev!!
Alright the first issue i had was the car not wanting to idle right, so i advanced the timing to 13 and it idled. now i go to rev it and the car leans out and want to die. i got the tps set to +05 and if i lower it the car dies.
heres my spec
S5 JDM 13BT streetport
720cc primary
1600cc secondarys
t04s p-trim 1.00 hotside .70 compressor
walbro 255 lph
i dont know what ecu info is needed but post do get it
Thanks
Old Jun 7, 2009 | 05:11 PM
rx72c's Avatar
Top Answer: 1
Ive seen the map in your car.
And the only reason the car would lean out on that map is because your secondaries are not coming on?
Is this the first time you have the car running? or was it running before and then it died?
Old Jun 8, 2009 | 12:02 AM
666cody666's Avatar
this is the first time it been started. it somehow fixed itself and it started to rev.so i drove it around and then it started to act up.i would try to accel. and then it leans and starts popping. i let the car sit off for a bit and the started it and it ran fine. so i think im going to need a new map
Old Jun 8, 2009 | 05:35 PM
rx72c's Avatar
Top Answer: 1
Their is a problem with your car not with the map.
If it drives fine sometimes and not others.
YOU HAVE A PROBLEM.
I have replied to your pms with ways of finding problems but if you dont want to look for it. Then thats up to you.
Prediict
32
Nov 18, 2015 08:41 AM
LongDuck
Oct 7, 2015 08:12 PM
Rotafuzz
Sep 30, 2015 09:55 AM
dexter snoek
Sep 29, 2015 09:18 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
