Sponsored by: CARiD
No fuel no spark - Motorswap
Old Jun 6, 2009 | 10:20 AM
kaioken's Avatar
Here is the run down. I have a 88 TII chassis with a S4 N/A motor out of a automatic mated to a TII trans. I have the N/A ecu, upper Emission harness and the lower harness. The nutural safety switch is wired. I can get the car to turn over. But right now I am not getting power back to the fuel pump. If I supply power to the pump the fuel pump runs and pressurizes the all the way up to the injectors.
I am thinking that my ECU is not getting power. The last owner had a mirotech install so that could be part of the wiring problems.
-Bill
I forgot to add that all the emissions devices are removed
Old Jun 14, 2009 | 07:50 PM
farberio's Avatar
NASA-MW ST4
If the last owner did a microtech install, he may have replaced the entire harness or ran a new wire to the fuel pump.
Pick up the carpet in the rear and check for any wiring changes to the fuel pump.
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
