Sponsored by: CARiD
all my dummy lights are on, what can i check?
Old May 31, 2002 | 09:53 AM
scott(pittsburgh)'s Avatar
i just put my new motor in, and all my dummy lights stay on after i start the car(ABS,charge, oil light and water light) all the fluids are good and the alt. is charging (removed the - terminal while car was running and nothing died) does anyone know what it may be?
thanks, scott
Old May 31, 2002 | 07:24 PM
Anderson's Avatar
When that happen to me BOTH my ALt and Battery were bad and I had no clue till they BOTH crapped out on me with in a 2 hour span.
So you might want to check that, and keep an eye on the volt meter.
Old Jun 8, 2002 | 05:02 PM
85RX7GS's Avatar
The alternator. Go to NAPA. NOW.
Old Jun 10, 2002 | 09:38 AM
then why did the car keep running when i removed the negative terminal from the battery?
and my pfc shoows like 13.7 volts when the motor is running.
Jutta_J
Mar 25, 2017 11:24 PM
Microtech
30
Apr 23, 2016 06:37 PM
rocker1337
16
Sep 6, 2015 11:28 PM
fastsaab
Aug 19, 2015 11:42 AM
