Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Unique Fabrication and Transplants
Single 90mm Throttle Body Mod for 3-rotor
Old May 31, 2009 | 05:54 PM
GtoRx7's Avatar
Collections Hold
We just finished up the single throttle body modification for the 20b upper intake manifold. 90mm in size, takes a D-shaft TPS, and standard throttle cable. We port out the inside to allow smooth flow to both primary and secondary runners. Will flow much more than the factory throttle body.
Price is $990.00
Old Jun 1, 2009 | 10:40 AM
RX-Heven's Avatar
I'll blow it up real good
You should just gut the inside of that plenum with that type of tb.
Old Jun 2, 2009 | 12:51 AM
joe-c's Avatar
YOUR MOM IS MY ADDICTION
Veteran: Navy
do you guys also offer than on the 13b-rew?
Old Jun 2, 2009 | 07:13 AM
ErnieT's Avatar
Living life 9 seconds at a time
Do yourself a favor, buy an Infinity Q45(Its a 90mm also) throttle body off E-Bay for $150. It comes with the TPS and you'll spend maybe another $150 to have it adapted to your UIM. Much cheaper and same size with a very nice return spring. BTW, this is what I did.
Old Jun 2, 2009 | 02:48 PM
GtoRx7's Avatar
Collections Hold
There is no need to cut apart the entire upper intake, have a nice weld line going through it, and achieve no performance gain while spending countless more hours in the process.
We can do the same mod for the 13b no problem.
This includes a TPS as well, forgot to mention it. If sent to us the intake is fully bead blasted, and the inside is ported out and smoothed as needed. The amount of hours to remove all that aluminum, and Tig weld on a adapter is high. A q45 is also not a true 90mm I.D. If I remember correctly, but not sure. Now please do us a favor and try not to disrespect our work by talking about a "cheaper" method you used. Make your own thread if you desire.
Old Jul 5, 2009 | 09:59 PM
dclin's Avatar
Perpetual Project
Excuse my ignorance, but will this support NA setup?
Old Jul 5, 2009 | 10:01 PM
^^I don't see why not big D
Old Jul 5, 2009 | 11:09 PM
dclin's Avatar
Perpetual Project
Hmmmm, k, maybe I need to actually get the FD back on the road before I start on something new. Still though, between this and the inclusion of the A/C and P/S in the latest update .... =P
Old Jul 6, 2009 | 01:26 AM
GtoRx7's Avatar
Collections Hold
Will work excellent in n/a setups too. We should have back to back dyno runs on n/a 20b within the next few months hopefully. The power increase will definitely be nice.
CaptainKRM
14
Aug 26, 2015 09:52 PM
