13b to 13bt swap
Old May 28, 2009 | 11:37 AM
V8 or Rotary's Avatar
13b to 13bt swap
do i need to get a turbo's driveshaft and a rear diff to make this swap work? or can i mount it up to the stock non turbo stuff and it be fine? for a little while...
Old May 28, 2009 | 01:44 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If using a turbo transmission, there are 2 options:
1) Use a turbo driveshaft and rear end
2) Use a custom turbo driveshaft with an NA diff flange. You can buy one from Mazdatrix or have one made from an auto driveshaft. The auto driveshaft has the turbo yoke and NA diff flange, but is 2" too short & must be extended.
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
