Passing Emissions Test
Old May 26, 2009 | 05:16 PM
1988 gul's Avatar
If i find an old 1986-91 rx7 at a junk yard with a stock turbo on it (rare find) could i put it on my '88 and still pass smog?
(I live in California, and it is a GTU if that matters)
Old Sep 3, 2009 | 12:29 AM
generalu's Avatar
Newbie
You need to post more information. If you're asking if you'll pass after you replace your turbo with the one you found in the junkyard - then the answer is maybe.
Old Sep 3, 2009 | 02:01 AM
funkjaw's Avatar
Do you mean putting a turbo on an NA motor? If that is the case, as long as you make the car look stock, than visually you should pass the smog. Emissions, probably not.
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
