new to rotary
Old May 25, 2009 | 08:15 PM
willrouse's Avatar
NC new to rotary
shade tree mechanic and fabricator lookin to build street drifter am lookin for 13b t and tranny for my 86 gxl
Old May 26, 2009 | 03:59 PM
farberio's Avatar
NASA-MW ST4
contact japan2la, you will probably have to make bunch of posts and then PM him.
Old May 31, 2009 | 07:51 PM
udon!'s Avatar
street drift ftw.
Old Jun 1, 2009 | 09:02 AM
Aaron Cake's Avatar
Engine, Not Motor
What is a "street drifter"?
Old Jun 1, 2009 | 01:43 PM
willrouse's Avatar
NC
it is a daily driver that can be taken to the track on sat and drifted already got a 82 mustang and a 88 supra that i play around with
Old Jun 1, 2009 | 03:54 PM
Aaron Cake's Avatar
Engine, Not Motor
As I understand it (and keep in mind that I know nothing about drifting), all you need to do is set up the car to oversteer.
So get a crappy set of rear tires, and swap them on when you get to the track. That's probably the easiest way to make a car tail happy yet keep it safe and fun on the street.
Old Jun 1, 2009 | 08:48 PM
Gunmetal87Coupe's Avatar
Resident sarcasm expert
So get tires from Walmart?
Old Jun 3, 2009 | 09:44 AM
Aaron Cake's Avatar
Engine, Not Motor
I really wouldn't know. From what I see about drifting it's kind of like figure skating. It seems to attract a big crowd of kids (unlike figure skating) and gets mixed up with things like DJs, bikini contests and video games. I'm too old for stuff like that.
Old Jun 3, 2009 | 12:58 PM
bose's Avatar
Your never too old for girls in bikini's.
Old Jun 3, 2009 | 11:56 PM
drift slut_fd's Avatar
Team HND
drifting is a little bit more complicated then having a bad set of tires my friend.....you need to make your car as soild as possible...for example....strut braces everywhere you can,good set of coilovers..make that car so it has zero body roll....2 way limited slip diff...so equal power is put to each tire(some you can get to lock up on high rpm down shifting)...and a decent amout of power with GOOD TIRES....drifting at high speed you must have good tires in order to push you forward while getting slideways...if not you will oversteer everytime....anyone can get the tires to spin....having full control is the hard part
Old Jun 4, 2009 | 09:06 AM
Transparent's Avatar
yea, bad tires are not what you want
Old Jun 4, 2009 | 10:05 AM
Aaron Cake's Avatar
Engine, Not Motor
Shows how much I know about drifting then. After all, I'm 30 years old so it's well out of my age range. I come from a time when cars are set up to handle and not oversteer.
Old Jun 5, 2009 | 07:09 PM
diablo_rx7's Avatar
rotary demon
i drift in mine its great way to get noticed by the honda ricers then they wanna race and i smoke them all day lol.
Old Jun 5, 2009 | 07:57 PM
willrouse's Avatar
NC
been gettin slideways u need a decent set of tires been doin it for several years now but really like the rotary set up with the rx7
Old Jun 5, 2009 | 09:02 PM
bose's Avatar
Would it be better to get some 'decent' tires that are used for starting out? What would you more experienced guys do?
Old Jun 8, 2009 | 04:53 AM
Rx Bassy's Avatar
thats what i need some strut bars
Old Jun 8, 2009 | 07:55 PM
Team HND
for starting out u could use a set of older tires or less tread tires to get the feel of your back end kicking and and how to conter steer and stuff like that.......but only at lower speeds and wider corners.....as soon as you start doing drifts at high speeds and big angle corners you need good tires to keep pushing the car forward while spining
Old Jun 8, 2009 | 08:53 PM
ncfc3s's Avatar
damn,......all kinds of info on drifting....so I should take my strut tower braces off to get my car to hook?
Old Jun 8, 2009 | 08:55 PM
ncfc3s's Avatar
Im already running 245 17 45s on one car with new bfgs....255s on the other one....they dont spin too much except when the turbo hits...well, the one with the OS clutch and flywheel does
Old Jun 8, 2009 | 09:41 PM
PacificTimeRx7's Avatar
whoo yes, drifting. hella tyte, yo!
Old Jun 9, 2009 | 11:55 PM
Team HND
no yu dont wont to take them off.....they help you eliminate body roll....if you have body roll its going to put most of the pressure on your outside tires and really wear off your sidewall...also with having strut braces makes your car able to turn qwick with a hard turn and a fast counter steer...you some be able to get sideways no matter what....all you really need the power for is keeping to rpms up so you can hold longer drifts and tweak them
Old Jun 11, 2009 | 01:45 PM
Handful's Avatar
International Expert
You can drift in a car with little modifications. Suspension, Tires should be the first. You dont need a ton of power to actually drift. But it helps at time.
Old Jun 11, 2009 | 03:04 PM
onionsncream's Avatar
Be kind, Redline!
NC
By street drifter do you mean an "illegal" drifter?
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
