FEED front fenders fitment help
Old May 19, 2009 | 09:08 PM
alex.hay's Avatar
Hey guys, I have searched far and wide but cant find anything so I thought id post this up.
I am trying to fit 17x10 +18 RPF1's with 280 wide slick on the front of the car with FEED front fenders (+25mm), I know it should work with a higher offset, but I was hoping this setup would be ok, what do you guys think? does anyone run a similar setup?
The issue is the 280 wide slick is a control tyre here in Aus, and the 17x10 +18 rpf1's I can get significantly cheaper than rrp, so its the ideal setup for me... if it will fit??
any ideas? Thanks
Old May 19, 2009 | 10:21 PM
purerx7's Avatar
Registered User
That is going to be close, with suspension and negative camber you can get it to work. I just ordered a set of feed front fenders, I plan on running an 18x9 + 20 on a 255.
Old May 25, 2009 | 07:28 AM
alex.hay's Avatar
cool thanks for the input, yea I think the wheel would be ok but I am still really unsure about fitting such a wide tyre?
the tyre size is actually 280/680x17 so its a real tall tyre as well, anyone have any experience fitting something like this up front?
Snoopy FD
Dec 8, 2015 01:45 PM
