V8 swap in First gen
Old May 19, 2009 | 06:33 PM
Clintthec's Avatar
I have a 1980 rx-7 and since it has a leaking seal in the motor i was thinking about just switching it out with my dad's old 307. Any suggestions because I have looked around the internet and have noticed Granny's Speed Shop is the most notable for doing these types of conversions.
Old May 20, 2009 | 09:29 AM
Aaron Cake's Avatar
Engine, Not Motor
"Old 302" seems to scream "cast iron, carbureted, POS". Forgive me if that is not correct but I have never, ever, seen the point of putting in an antiquated lump of cast iron when there are far better V8s available.
There is an "Other Engine Conversions" subforum here which will probably provide all the information you need.
Old May 20, 2009 | 02:59 PM
NoPistons!'s Avatar
Tango Down
I thought all v8 heads in south carolina could do all sorts of ghetto to make v8's fit in rwd chassis......
REBAR MOTOR MOUNTS!!!!!
I've seen it.
That motor probably weighs more than the car.
Old May 20, 2009 | 03:42 PM
Clintthec's Avatar
No the motor only actually weighs at most 50 pounds heavier and the reason for not a new V8 is money i have a 307 my dad has so therefore thats the way it goes hahaha. And i dont wanna ghetto rig it why make it ugly when it could be so much better
Old May 20, 2009 | 05:41 PM
NoPistons!'s Avatar
Tango Down
Well hey, do what you do.
If you are staying carb, there's really nothing to it. All you'll need is the proper trans and driveshaft.
Fab your own mounts. Run a rear sump pan. Cut the hood for air cleaner clearance. Run a bigger fuel pump and you're done.
You may or may not need custom headers. All depends on how it fits. You could just modify the stockers to fit if need be.
It's not rocket science.
www.v8rx7forums.com
check it out.
Old May 21, 2009 | 03:03 PM
Clintthec's Avatar
Ok thanks i porbably wont have to cut the hood it should all fit under to keep a nice sleeper look. haha Ad probably buy some headers that go straight back.
Old May 23, 2009 | 03:52 AM
mar3's Avatar
Administrator
If the 307 is the old Chevy engine, that's one of the worst things you could do...it's all of 165 HP, you can't build it up because of the thinwall castings and the heads are emissions horrendous. It is FAR more than 50 lbs heavier with all the stuff on it...bare block to bare block, it's still at least 75 heavier than the 12A.
Mario III
Old May 23, 2009 | 10:26 AM
Clintthec's Avatar
Well as seeing it was rebuilt by aunt and has a racing cam in it i am more than happy to put it in there as seeing my rotary has leaking seals and its more of a project car for me and my dad. That 12a is not a light one itself btw.
Old May 24, 2009 | 09:59 AM
Aaron Cake's Avatar
Engine, Not Motor
12A block weighs about 165 LBs. I know because that's 20 pounds more then I weigh and I can lift one. The exhaust system, though, weighs in at 17.4 metric tons.
Old May 24, 2009 | 11:39 AM
Clintthec's Avatar
lol haha yeah i must agree with that the exhuast system is a monster as seeing i just took it off i was like what is this stuff lead haha
Old May 24, 2009 | 01:20 PM
tranquilo's Avatar
Rotary Ganja
goodluck with your project
Old May 26, 2009 | 06:21 AM
Clintthec's Avatar
Thanks well i know its going to be an interesting one at the least lol
