where does this hose go to?
Old May 19, 2009 | 04:21 PM
ryder2489's Avatar
baller on a budget
Unhappy where does this hose go to?
there is this hose which i cant figure what to connect to
by the way the intake, radiator, fan were not install when i got it so i had to install them
laters
Old May 20, 2009 | 12:05 AM
mar3's Avatar
Administrator
Well, on a carb'd 1stgen, that hose would go back to the air intake tube of a 3-way catalytic converter....however, since I'm assuming this is a shot of your FC engine bay, I'll let the 2ndgen guru's take this one away...
Mario III
Old May 20, 2009 | 12:09 AM
lastphaseofthis's Avatar
My job is to blow **** up
it is the Fresh Air supply to your CAT, should be a check valve then a long metal tube that attaches and goes way back to the last cat, not required to run, but your cats will surely burn up with out it.
Old May 23, 2009 | 12:06 AM
ryder2489's Avatar
baller on a budget
alright thanks man i hook everythin up and it starts and runs but damn it smoke alot!!!!
