Please help identify wire... Under Driverside
Old May 17, 2009 | 08:21 PM
s1mpsons's Avatar
HamfistRacing.com
This wire I found just hanging down between my subframe near my steering column. It is not connected to anything. Any help would be much appreciated.
Old May 17, 2009 | 08:32 PM
IRPerformance's Avatar
Sponsor
Wire on the left is the oil level sensor wire. The one on the right doesn't look factory.
Old May 17, 2009 | 10:45 PM
s1mpsons's Avatar
HamfistRacing.com
It's the same wire, just for cut off in the picture. How do I reconnect?
Old May 19, 2009 | 01:46 PM
s1mpsons's Avatar
HamfistRacing.com
Can someone please advise where it is supposed to connect to? Where is the oil level sender unit?
Old May 19, 2009 | 01:50 PM
Sponsor
Driver side of oil pan. Solder the wire back together and insulate it with heat shrink. If the wire broke right at the sender you will need a new one.
Old May 19, 2009 | 02:37 PM
s1mpsons's Avatar
HamfistRacing.com
What does the sender look like? Picture?
<--- NOOB
Old Oct 24, 2009 | 06:42 PM
s1mpsons's Avatar
HamfistRacing.com
Why, if this wire is cut/damaged, does the oil level light not stay on while I am driving?
Note, the light DOES come on when I start the car, so I know the bulb is OK.
Old Oct 24, 2009 | 08:20 PM
badddrx7's Avatar
All Spooled Up
Oil level sensor is on the oil pan driver side. You sender's wire has broken loose. When this happens usually there is nothing to solder it back to. Call Ray at Malloy Mazda and order a new oil level sensor and install it.
Later
Old Oct 24, 2009 | 08:34 PM
s1mpsons's Avatar
HamfistRacing.com
Later
Thanks. But what about my "light" issue?
Old Oct 24, 2009 | 10:46 PM
Julian's Avatar
light probable only goes on when sensor goes to grnd, cut wire is still not grounded
Old Oct 25, 2009 | 08:08 AM
badddrx7's Avatar
All Spooled Up
When it is connected it is grounded and light stays out, when cut off light is on. Light tells you right now to call Ray at Malloy and get a new sensor and to NOT just ground the wire to get your light out. Short cutting this safeguard may cost you an engine rebuild.
your welcome
LAter
Old Oct 26, 2009 | 07:44 PM
twisted7's Avatar
Jake
your welcome
LAter
Can you go more indepth please. I kid I kid. Do as Tom is telling you or check and see if the wire coming out of your oil pan is cut somewhere. More than likely it did just break off at the Pan. The sensor is on the Driverside facing the driverside fender.
vqturbo
Old School and Other Rotary
32
Aug 11, 2023 07:29 PM
pzr2
Sep 8, 2015 10:46 AM
Frox
Sep 8, 2015 08:36 AM
ppritchard
Interior / Exterior / Audio
Sep 2, 2015 07:44 PM
