Headlight Bolt
Old May 16, 2009 | 08:18 AM
Ceylon's Avatar
Non Runner
Headlight Bolt
Hi
Does anyone happen to know the part number or where I can get this bolt?
Its the one that fixes the pop-up lights to the car, 2 per light.
I have searched, but with no luck.
Cheers
Ceylon.
Old May 16, 2009 | 01:31 PM
Zyon13B's Avatar
"I see triangles"
There's actually 7 bolts that fasten the pop-ups. Can you be more specific, or take a pic?
Old May 16, 2009 | 02:25 PM
Ceylon's Avatar
Non Runner
There is only two of this type, its the two that attach the pop-ups.
Heres a picture - I put a red ring around them to indentify them.
Thanks.
Ceylon.
Old May 18, 2009 | 03:07 AM
Ceylon's Avatar
Non Runner
Any ideas? Or a suggestion of where I can find it?
Cheers
Old May 19, 2009 | 04:22 AM
billyboy's Avatar
Probably can't find a number 'cause the bolts only come as part of the fibreglass headlight assembly. Without dismantling a smashed unit, length is about 18mm, thread is 6mm - expect there is a shoulder on the bolt to act as a pivot or something else funky happening, because visually, appears like there is a 12mm hex on the bolt, rather than the usual 10mm.
Old May 20, 2009 | 03:36 PM
gflenn's Avatar
I think that's the same one I lost several years ago. If it's the pivot bolt it has a shoulder on it that acts llike a bushing. I went to a salvage yard and pulled a couple from and FC(I think) which worked perfect. I'd send you an extra if I have one but I see you're across the pond.
gary
Old May 20, 2009 | 03:46 PM
MyRedFD's Avatar
Enter Title Here
Have you tried taking one off and going to a parts or hardware store to see if they have something similar? I have a whole extra set of these and can send one over but the cost to ship it would be way more than one would cost over there, unless you really want to pay to cover that.
Old May 21, 2009 | 04:02 AM
Ceylon's Avatar
Non Runner
Ok, thanks guys
I will have a look.
Cheers
Ceylon
wa11yba11s
Oct 16, 2015 09:54 AM
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
