85 GSL from lug bolts to nuts???
Old May 14, 2009 | 06:56 PM
1BadRx7331's Avatar
ID 85 GSL from lug bolts to nuts???
I have an 85 GSL that i want to do a GSL-SE conversion from lug bolts to lug nuts. i decided this after i bought a set of wheels that when i tried to mount them my stock lug bolts were to short to mount them. i also want to upgrade to drilled and slotted rotors which i could'nt find for the stock set up. i need someone selling the necessary parts as well as a full list of all the parts i will need. any input will help. i have seen people screw studs into the female rotor holes and then using lugnuts on them, is that a good idea?
Old May 15, 2009 | 09:24 PM
1BadRx7331's Avatar
a bump for some help? :-)
Old May 16, 2009 | 02:23 PM
1BadRx7331's Avatar
Any help at all?
DerpyToast
14
Nov 23, 2024 05:19 PM
