ignition identification?
Old May 11, 2009 | 08:07 PM
etx4's Avatar
etx4
I have searched the forums for bout two hours now, (the amount of info is exausting - i might just suck at searching) and did not find the answer I am looking for, the question is this: does my wiring at my ignition switch have to be soldered when i replace it?
This is where I am at:
1. from what I have read about a recent problem- hazards and wipers went out, probably the ignition switch--
2. then today, nothing happens when I turn the key, and I just put in a new battery last month! - okay, probably the ignition switch finally went completely out...
3. I removed the horn and plastic housing from the steering column and discovered soldered wires(i have never messed with this before) and I dont know how to remove or repair them.
Any help with further diagnosis or tips would be helpful, seeing as how I am flat broke and am doomed to repair this myself...
Old May 11, 2009 | 10:06 PM
mar3's Avatar
Administrator
Yes...and since a ball of solder is already at the terminals, it's just a matter of heating it up to liquify it and pushing the wire in again, in most cases. I had a pic from an ancient case of 1stgen RX-7 not wanting to start all the time when the ignition key was turned over, but it's on the ancient W98 PC that's sitting in the corner gathering dust. I'll bring it online tomorrow night and download the pic if you haven't gotten better help by then.
First, though, we need to know what YEAR car you're dealing with...
Mario III
Old May 12, 2009 | 02:03 AM
thejallenator's Avatar
Mario III
hya by the time you get that thing up and running he will have prolly have another probllem. a pc with 98 will take 6 days to turn on
Old May 12, 2009 | 06:42 AM
kbuby's Avatar
first, though, we need to know what year car you're dealing with...
x2
Old May 12, 2009 | 07:18 PM
etx4's Avatar
etx4
my car is: 85 with 12a and Nikki. all stock, except inards of the carb- carb was rebuilt by rotary performance in Garland, TX- the recommended upgrading the seats with a bearing type(or something like that)
Everything else should be stockas far as I know-- and btw: I'm hoping you can verify my suspect diagnosis that an ignition switch could also be the culprit for my windshield wipers being stuck and not working, and hazards not working at all-- for this problem I have already checked all the dash fuses, and none are blown.
in another thread someone IDed it as a possible cause...
thanks again--
Old May 14, 2009 | 04:25 PM
mar3's Avatar
Administrator
If they aren't used on a regular basis, the wiper rack tends to rust and freeze up beyond fixing status....try to work the rack by hand or run your battery volts, via jumper wires, directly into the harness clip of the rack to see if it's still good. Let me hook up the W98 tonight...I wrote a postie to myself so I'll be sure to remember...
Old May 14, 2009 | 10:36 PM
mar3's Avatar
Administrator
Here's the only two pics I could find...the car wouldn't start consistently, sometimes the accessories would all not work, no blower fan, no radio, etc....I worked the solder points seen here, but it turned out to be the actual plastic cap all that stuff sits on. I used the purple zip tie to re-establish the correct contact force on that ignition switch and that cured the problems.
...and no, I don't remember what all the arrows were for anymore...those pics were part of an old tech thread I did way in the past...I'd have to dig that thread back up to get the answers...
Attached Thumbnails ignition identification?-ignition-switch-fix-84.jpg   ignition identification?-igniton-switch-fix2-84.jpg
Old May 14, 2009 | 11:45 PM
rxtasy3's Avatar
i have a compaq running 98. it's actually alittle faster surfing the net than an hp i have running xp. i figure it the network card tho.
Old May 15, 2009 | 05:19 PM
etx4's Avatar
etx4
yes it seems to want to work now!!! thanks for all the help-- I've got hazards, but now, because it rained and wipers werent working, they rusted in the up position!! lol
I'll be cleaning those up soon-0-0
Thank You again for taking the time to advise me!
Jody
Old May 16, 2009 | 12:10 PM
mar3's Avatar
Administrator
That's what we're here for...to make sure you keep on enjoying that RX-7 and keep it on the road! Glad things are working out for you and the car!
Mario III
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
