is this possible?
Old May 10, 2009 | 08:16 PM
craig3x's Avatar
is this possible?
is it possible to run a turbo on the weber 48? I have a modified 13b with the weber carb setup. Does anyone make a turbo set up for this?
Old May 10, 2009 | 09:04 PM
thejallenator's Avatar
it is possible to make a carb'd engine turboed. you have to make a sealed box over the inlet on the carb. that way the pressurized air doesnt escape.
Old May 11, 2009 | 09:27 AM
another7driver's Avatar
Listener
Rotary Shack does custom carb hats for turbo applications. These kinds of setups are few and far between, it would probably be best to ask them about your application.
Old May 11, 2009 | 09:43 AM
Aaron Cake's Avatar
Engine, Not Motor
Do a quick search for "boost prep weber" and you should find the info. As I recall, you need copper floats, a rising rate FPR and a plenum.
Old May 11, 2009 | 11:45 AM
craig3x's Avatar
Thanks, I will do some more research
